[Swift-devel] Re: coaster->tg-ncsa
    Mihael Hategan
    hategan at mcs.anl.gov
    Tue Apr 29 21:51:01 CDT 2008
Odd. Attributes should be copied from the original task. I'll look into
that.
On Wed, 2008-04-30 at 02:47 +0000, Ben Clifford wrote:
> I set GLOBUS_HOSTNAME and ran with gram2 again. It got further... sits and
> waits for quite a long time and then the below error (because I
> deliberately don't have a default project on teragrid sites, instead
> setting it via a profile entry in the appropriate sites file to whichever
> of the three I'm in)
> Caused by:
> ERROR: you must either specify an account (project=xxx) or log in to
>        the system to set a default account. Here are your accounts:
> NCSA                                   Days     Service Units   Avail for
> Proj  TG Account    Type     Status  Remaining    Remaining     Batch Jobs
> bdd  TG-CDA070002   prb      Active        1         28387         yes
> brn  TG-CCR080001   prb      Active      155         28970         yes
> brv  TG-CCR080002   prb      Active      155         29559         yes
>  *** Job not submitted ***
> null
> org.globus.gram.GramException: The job failed when the job manager
> attempted to run it
>         at
> org.globus.cog.abstraction.impl.execution.gt2.JobSubmissionTaskHandler.statusChanged(JobSubmissionTaskHandler.java:476)
>         at org.globus.gram.GramJob.setStatus(GramJob.java:184)
>         at
> org.globus.gram.GramCallbackHandler.run(CallbackHandler.java:176)
>         at java.lang.Thread.run(Thread.java:534)
