[Swift-devel] coasters
Mihael Hategan hategan at mcs.anl.gov
Tue Apr 22 10:46:14 CDT 2008
GLOBUS_HOSTNAME should work, so it might be another problem. Send log
file. Also, try invoking the integrated test
(org.globus.cog.abstraction.impl.execution.coaster.JobSubmissionTaskHandler.main()).
On Tue, 2008-04-22 at 15:41 +0000, Ben Clifford wrote:
> On Tue, 22 Apr 2008, Mihael Hategan wrote:
> > You need a valid IP in your cog.properties.
> Is there a way for me to set that in a way that doesn't involve fiddling
> with files outside of my install/run tree?
> (neither GLOBUS_HOSTNAME env or -ip.addr swift command line parameter
> changes the error)
