On Tue, 22 Apr 2008, Mihael Hategan wrote: > You need a valid IP in your cog.properties. Is there a way for me to set that in a way that doesn't involve fiddling with files outside of my install/run tree? (neither GLOBUS_HOSTNAME env or -ip.addr swift command line parameter changes the error) --
