[Swift-devel] swift 0.5 and gt2
    Mihael Hategan
    hategan at mcs.anl.gov
    Tue Apr 22 07:49:36 CDT 2008
On Tue, 2008-04-22 at 03:54 +0000, Ben Clifford wrote:
> On Mon, 21 Apr 2008, Mihael Hategan wrote:
> > It may be that if you submit jobs through gt2 with swift 0.5 they may be
> > run with fork even though other job managers are specified.
> > This needs to be checked, but that's what my code shows.
> That's contrary to what the per-site testin in tests/sites/ shows. I just
> checked again with the 0.5 tarball using tests/sites/tgtacc-lsf-gram2.xml
> and I see jobs going into LSF there.
> Did you use a jobmanager specification syntax that differs from the syntax
> used in that file? If so, what?
The gt2 provider was using undocumented stuff to read the job manager
from a description. And that undocumented stuff has changed. Can it be
that LSF is the default there?
