[Swift-devel] swift 0.5 and gt2
Ben Clifford
benc at hawaga.org.uk
Mon Apr 21 22:54:07 CDT 2008
On Mon, 21 Apr 2008, Mihael Hategan wrote:
> It may be that if you submit jobs through gt2 with swift 0.5 they may be
> run with fork even though other job managers are specified.
> This needs to be checked, but that's what my code shows.
That's contrary to what the per-site testin in tests/sites/ shows. I just
checked again with the 0.5 tarball using tests/sites/tgtacc-lsf-gram2.xml
and I see jobs going into LSF there.
Did you use a jobmanager specification syntax that differs from the syntax
used in that file? If so, what?
