[Swift-devel] Re: Can not reach advertised gridftp server on Abe
    help at teragrid.org
    Mon Apr 14 15:04:09 CDT 2008
(Concerning ticket No. 154784)
Hello Michael,
Our Grid Services Folks are working on the issue, in the meantime you can use
  login-abe.ncsa.teragrid.org
instead of
  gridftp-abe.ncsa.teragrid.org
and we will notify you once the issue has been resolved.
We appologize for any inconvenience.
-Weddie
Weddie Jackson
NCSA Consulting Services
Michael Wilde <help at teragrid.org> writes:
>Hi Help Team,
>When I try to reach the gridftp server on Abe advertised in the Userinfo
>pages at, which is:
>on page:
>http://www.teragrid.org/userinfo/hardware/resources.php?
type=compute&select=single&id=50&PHPSESSID=2379360d3ce483f8f90532609354cd73
>then I get the following error:
># my cert is ok:
>login$ globus-job-run grid-abe.ncsa.teragrid.org /bin/hostname
>honest4.ncsa.uiuc.edu
># this fails:
>login$ globus-url-copy file:///etc/passwd
>gsiftp://gridftp-abe.ncsa.teragrid.org/cfs/scratch/users/wilde/fromci
>error: globus_ftp_client: the server responded with an error
>530 530-Login incorrect. : IPC connection failed.
>530-globus_xio_gsi: gss_init_sec_context failed.
>530-GSS Major Status: Unexpected Gatekeeper or Service Name
>530-globus_gsi_gssapi: Authorization denied: The name of the remote host
>(abe-ipib-gw02.ncsa.uiuc.edu), and the expected name for the remote host
>(abe-gw02) do not match. This happens when the name in the host
>certificate does not match the information obtained from DNS and is
>often a DNS configuration problem.
>530 End.
># while gridftp to the GRAM gatekeeper host works:
>gsiftp://grid-abe.ncsa.teragrid.org/cfs/scratch/users/wilde/fromci
>login$
