[Swift-devel] Can not reach advertised gridftp server on Abe
Michael Wilde wilde at mcs.anl.gov
Mon Apr 14 13:49:24 CDT 2008
Hi Help Team,
When I try to reach the gridftp server on Abe advertised in the Userinfo
pages at, which is:
   gridftp-abe.ncsa.teragrid.org
on page:
http://www.teragrid.org/userinfo/hardware/resources.php?type=compute&select=single&id=50&PHPSESSID=2379360d3ce483f8f90532609354cd73
then I get the following error:
# my cert is ok:
login$ globus-job-run grid-abe.ncsa.teragrid.org /bin/hostname
honest4.ncsa.uiuc.edu
# this fails:
login$ globus-url-copy file:///etc/passwd
gsiftp://gridftp-abe.ncsa.teragrid.org/cfs/scratch/users/wilde/fromci
error: globus_ftp_client: the server responded with an error
530 530-Login incorrect. : IPC connection failed.
530-globus_xio_gsi: gss_init_sec_context failed.
530-GSS Major Status: Unexpected Gatekeeper or Service Name
530-globus_gsi_gssapi: Authorization denied: The name of the remote host
(abe-ipib-gw02.ncsa.uiuc.edu), and the expected name for the remote host
(abe-gw02) do not match. This happens when the name in the host
certificate does not match the information obtained from DNS and is
often a DNS configuration problem.
530 End.
# while gridftp to the GRAM gatekeeper host works:
gsiftp://grid-abe.ncsa.teragrid.org/cfs/scratch/users/wilde/fromci
login$
A problem due to multi-homed hosts or multiple hostname aliases?
Is gridftp-abe a beefier data server than grid-abe, and if so should the
problem above get fixed?
- Mike
