[Swift-devel] Re: Another performance comparison of DOCK
Ioan Raicu
iraicu at cs.uchicago.edu
Sun Apr 13 18:45:28 CDT 2008
OK, sounds good. Zhao, when you get the chance, maybe you could try 100
instead of 2000 for the file limits? I don't know if this is a top
priority right now, but certainly for after SC.
"throttle.file.operations=100"
Ioan
Mihael Hategan wrote:
> On Sun, 2008-04-13 at 18:22 -0500, Ioan Raicu wrote:
>> We are not using GridFTP on the BG/P, where this test was done. Files
>> are already on GPFS, so the stageins are probably just cp (or ln -s)
>> from one place to another on GPFS. Is your suggestion still to set that
>> 2000 back down to 100?
> I see. So it's the local provider. Well, mileage may vary. 100
> concurrent transfers doesn't seem very far from what I'd expect if we're
> talking about small files.
>> Ioan
>>> Then my guess is that the system itself (swift + server + FS) cannot
>>> sustain a much higher rate than 100 things per second. In principle
>>> setting those throttles to 2000 pretty much means that you're trying to
>>> start 2000 gridftp connections and hence 2000 gridftp processes on the
>>> server.
>>> On Sun, 2008-04-13 at 17:58 -0500, Zhao Zhang wrote:
>>>> Hi, Mike
>>>> It is just a typo in the email. I my property file, it is
>>>> "throttle.file.operations=2000". Thanks.
>>>> zhao
>>>> Michael Wilde wrote:
>>>>>>> If its set right, any chance that Swift or Karajan is limiting it
>>>>>>> somewhere?
>>>>>> 2000 for sure,
>>>>>> throttle.submit=off
>>>>>> throttle.host.submit=off
>>>>>> throttle.score.job.factor=off
>>>>>> throttle.transfers=2000
>>>>>> throttle.file.operation=2000
>>>>> Looks like a typo in your properties, Zhao - if the text above came
>>>>> from your swift.properties directly:
>>>>> vs operations with an s as per the properties doc:
>>>>> throttle.file.operations=8
>>>>> #throttle.file.operations=off
>>>>> Which doesnt explain why we're seeing 100 when the default is 8 ???
>>>>> - Mike
>>>>> On 4/13/08 3:39 PM, Zhao Zhang wrote:
>>>>>> Hi, Mike
>>>>>>> Ben, your analysis sounds very good. Some notes below, including
>>>>>>> questions for Zhao.
>>>>>>> On 4/13/08 2:57 PM, Ben Clifford wrote:
>>>>>>>>> Ben, can you point me to the graphs for this run? (Zhao's
>>>>>>>>> *99cy0z4g.log)
>>>>>>>> http://www.ci.uchicago.edu/~benc/report-dock2-20080412-1609-99cy0z4g
>>>>>>>>> Once stage-ins start to complete, are the corresponding jobs
>>>>>>>>> initiated quickly, or is Swift doing mostly stage-ins for some
>>>>>>>>> period?
>>>>>>>> In the run dock2-20080412-1609-99cy0z4g, jobs are submitted (to
>>>>>>>> falkon) pretty much right as the corresponding stagein completes. I
>>>>>>>> have no deeper information about when the worker actually starts to
>>>>>>>> run.
>>>>>>>>> Zhao indicated he saw data indicating there was about a 700 second
>>>>>>>>> lag from
>>>>>>>>> workflow start time till the first Falkon jobs started, if I
>>>>>>>>> understood
>>>>>>>>> correctly. Do the graphs confirm this or say something different?
>>>>>>>> There is a period of about 500s or so until stuff starts to happen;
>>>>>>>> I haven't looked at it. That is before stage-ins start too, though,
>>>>>>>> which means that i think this...
>>>>>>>>> If the 700-second delay figure is true, and stage-in was
>>>>>>>>> eliminated by copying
>>>>>>>>> input files right to the /tmp workdir rather than first to
>>>>>>>>> /shared, then we'd
>>>>>>>>> have:
>>>>>>>>> 1190260 / ( 1290 * 2048 ) = .45 efficiency
>>>>>>>> calculation is not meaningful.
>>>>>>>> I have not looked at what is going on during that 500s startup
>>>>>>>> time, but I plan to.
>>>>>>> Zhao, what SVN rev is your Swift at? Ben fixed an N^2 mapper
>>>>>>> logging problem a few weeks ago. Could that cause such a delay, Ben?
>>>>>>> It would be very obvious in the swift log.
>>>>>> The version is Swift svn swift-r1780 cog-r1956
>>>>>>>>> I assume we're paying the same staging price on the output side?
>>>>>>>> not really - the output stageouts go very fast, and also because
>>>>>>>> job ending is staggered, they don't happen all at once.
>>>>>>>> This is the same with most of the large runs I've seen (of any
>>>>>>>> application) - stageout tends not to be a problem (or at least, no
>>>>>>>> where near the problems of stagein).
>>>>>>>> All stageins happen over a period t=400 to t=1100 fairly smoothly.
>>>>>>>> There's rate limiting still on file operations (100 max) and file
>>>>>>>> transfers (2000 max) which is being hit still.
>>>>>>> I thought Zhao set file operations throttle to 2000 as well. Sounds
>>>>>>> like we can test with the latter higher, and find out what's
>>>>>>> limiting the former.
>>>>>>> Zhao, what are your settings for property throttle.file.operations?
>>>>>>> I assume you have throttle.transfers set to 2000.
>>>>>>> somewhere?
>>>>>> 2000 for sure,
>>>>>> throttle.submit=off
>>>>>>>> I think there's two directions to proceed in here that make sense
>>>>>>>> for actual use on single clusters running falkon (rather than
>>>>>>>> trying to cut out stuff randomly to push up numbers):
>>>>>>>> i) use some of the data placement features in falkon, rather than
>>>>>>>> Swift's
>>>>>>>> relatively simple data management that was designed more for
>>>>>>>> running
>>>>>>>> on the grid.
>>>>>>> Long term: we should consider how the Coaster implementation could
>>>>>>> eventually do a similar data placement approach. In the meantime
>>>>>>> (mid term) examining what interface changes are needed for Falkon
>>>>>>> data placement might help prepare for that. Need to discuss if that
>>>>>>> would be a good step or not.
>>>>>>>> ii) do stage-ins using symlinks rather than file copying. this makes
>>>>>>>> sense when everything is living in a single filesystem, which
>>>>>>>> again
>>>>>>>> is not what Swift's data management was originally optimised for.
>>>>>>> I assume you mean symlinks from shared/ back to the user's input files?
>>>>>>> That sounds worth testing: find out if symlink creation is fast on
>>>>>>> NFS and GPFS.
>>>>>>> Is another approach to copy direct from the user's files to the /tmp
>>>>>>> workdir (ie wrapper.sh pulls the data in)? Measurement will tell if
>>>>>>> symlinks alone get adequate performance. Symlinks do seem an easier
>>>>>>> first step.
>>>>>>>> I think option ii) is substantially easier to implement (on the
>>>>>>>> order of days) and is generally useful in the single-cluster,
>>>>>>>> local-source-data situation that appears to be what people want to
>>>>>>>> do for running on the BG/P and scicortex (that is, pretty much
>>>>>>>> ignoring anything grid-like at all).
>>>>>>> Grid-like might mean pulling data to the /tmp workdir directly by
>>>>>>> the wrapper - but that seems like a harder step, and would need
>>>>>>> measurement and prototyping of such code before attempting. Data
>>>>>>> transfer clients that the wrapper script can count on might be an
>>>>>>> obstacle.
>>>>>>>> Option i) is much harder (on the order of months), needing a very
>>>>>>>> different interface between Swift and Falkon than exists at the
>>>>>>>> moment.
>>>> _______________________________________________
>>>> Swift-devel mailing list
>>>> Swift-devel at ci.uchicago.edu
>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
>> Ioan Raicu
>> Ph.D. Candidate
>> Distributed Systems Laboratory
>> Computer Science Department
>> University of Chicago
>> 1100 E. 58th Street, Ryerson Hall
>> Chicago, IL 60637
>> Email: iraicu at cs.uchicago.edu
>> Web: http://www.cs.uchicago.edu/~iraicu
>> http://dev.globus.org/wiki/Incubator/Falkon
>> http://dsl-wiki.cs.uchicago.edu/index.php/Main_Page
Ioan Raicu
Ph.D. Candidate
Chicago, IL 60637
