[Swift-devel] Re: Another performance comparison of DOCK
    Mihael Hategan
    hategan at mcs.anl.gov
    Sun Apr 13 17:41:20 CDT 2008
On Sun, 2008-04-13 at 18:22 -0500, Ioan Raicu wrote:
> We are not using GridFTP on the BG/P, where this test was done.  Files
> are already on GPFS, so the stageins are probably just cp (or ln -s)
> from one place to another on GPFS.  Is your suggestion still to set that
> 2000 back down to 100?
I see. So it's the local provider. Well, mileage may vary. 100
concurrent transfers doesn't seem very far from what I'd expect if we're
talking about small files.
> Ioan
> Mihael Hategan wrote:
> > Then my guess is that the system itself (swift + server + FS) cannot
> > sustain a much higher rate than 100 things per second. In principle
> > setting those throttles to 2000 pretty much means that you're trying to
> > start 2000 gridftp connections and hence 2000 gridftp processes on the
> > server.
> > On Sun, 2008-04-13 at 17:58 -0500, Zhao Zhang wrote:
> >> Hi, Mike
> >> It is just a typo in the email. I my property file, it is
> >> "throttle.file.operations=2000". Thanks.
> >> zhao
> >> Michael Wilde wrote:
> >>>>> If its set right, any chance that Swift or Karajan is limiting it
> >>>>> somewhere?
> >>>> 2000 for sure,
> >>>> throttle.submit=off
> >>>> throttle.host.submit=off
> >>>> throttle.score.job.factor=off
> >>>> throttle.transfers=2000
> >>>> throttle.file.operation=2000
> >>> Looks like a typo in your properties, Zhao - if the text above came
> >>> from your swift.properties directly:
> >>> vs operations with an s as per the properties doc:
> >>> throttle.file.operations=8
> >>> #throttle.file.operations=off
> >>> Which doesnt explain why we're seeing 100 when the default is 8 ???
> >>> - Mike
> >>> On 4/13/08 3:39 PM, Zhao Zhang wrote:
> >>>> Hi, Mike
> >>>>> Ben, your analysis sounds very good. Some notes below, including
> >>>>> questions for Zhao.
> >>>>> On 4/13/08 2:57 PM, Ben Clifford wrote:
> >>>>>>> Ben, can you point me to the graphs for this run? (Zhao's
> >>>>>>> *99cy0z4g.log)
> >>>>>> http://www.ci.uchicago.edu/~benc/report-dock2-20080412-1609-99cy0z4g
> >>>>>>> Once stage-ins start to complete, are the corresponding jobs
> >>>>>>> initiated quickly, or is Swift doing mostly stage-ins for some
> >>>>>>> period?
> >>>>>> In the run dock2-20080412-1609-99cy0z4g, jobs are submitted (to
> >>>>>> falkon) pretty much right as the corresponding stagein completes. I
> >>>>>> have no deeper information about when the worker actually starts to
> >>>>>> run.
> >>>>>>> Zhao indicated he saw data indicating there was about a 700 second
> >>>>>>> lag from
> >>>>>>> workflow start time till the first Falkon jobs started, if I
> >>>>>>> understood
> >>>>>>> correctly. Do the graphs confirm this or say something different?
> >>>>>> There is a period of about 500s or so until stuff starts to happen;
> >>>>>> I haven't looked at it. That is before stage-ins start too, though,
> >>>>>> which means that i think this...
> >>>>>>> If the 700-second delay figure is true, and stage-in was
> >>>>>>> eliminated by copying
> >>>>>>> input files right to the /tmp workdir rather than first to
> >>>>>>> /shared, then we'd
> >>>>>>> have:
> >>>>>>> 1190260 / ( 1290 * 2048 ) = .45 efficiency
> >>>>>> calculation is not meaningful.
> >>>>>> I have not looked at what is going on during that 500s startup
> >>>>>> time, but I plan to.
> >>>>> Zhao, what SVN rev is your Swift at?  Ben fixed an N^2 mapper
> >>>>> logging problem a few weeks ago. Could that cause such a delay, Ben?
> >>>>> It would be very obvious in the swift log.
> >>>> The version is Swift svn swift-r1780 cog-r1956
> >>>>>>> I assume we're paying the same staging price on the output side?
> >>>>>> not really - the output stageouts go very fast, and also because
> >>>>>> job ending is staggered, they don't happen all at once.
> >>>>>> This is the same with most of the large runs I've seen (of any
> >>>>>> application) - stageout tends not to be a problem (or at least, no
> >>>>>> where near the problems of stagein).
> >>>>>> All stageins happen over a period t=400 to t=1100 fairly smoothly.
> >>>>>> There's rate limiting still on file operations (100 max) and file
> >>>>>> transfers (2000 max) which is being hit still.
> >>>>> I thought Zhao set file operations throttle to 2000 as well.  Sounds
> >>>>> like we can test with the latter higher, and find out what's
> >>>>> limiting the former.
> >>>>> Zhao, what are your settings for property throttle.file.operations?
> >>>>> I assume you have throttle.transfers set to 2000.
> >>>>> somewhere?
> >>>> 2000 for sure,
> >>>> throttle.submit=off
> >>>>>> I think there's two directions to proceed in here that make sense
> >>>>>> for actual use on single clusters running falkon (rather than
> >>>>>> trying to cut out stuff randomly to push up numbers):
> >>>>>>  i) use some of the data placement features in falkon, rather than
> >>>>>> Swift's
> >>>>>>     relatively simple data management that was designed more for
> >>>>>> running
> >>>>>>     on the grid.
> >>>>> Long term: we should consider how the Coaster implementation could
> >>>>> eventually do a similar data placement approach. In the meantime
> >>>>> (mid term) examining what interface changes are needed for Falkon
> >>>>> data placement might help prepare for that. Need to discuss if that
> >>>>> would be a good step or not.
> >>>>>>  ii) do stage-ins using symlinks rather than file copying. this makes
> >>>>>>      sense when everything is living in a single filesystem, which
> >>>>>> again
> >>>>>>      is not what Swift's data management was originally optimised for.
> >>>>> I assume you mean symlinks from shared/ back to the user's input files?
> >>>>> That sounds worth testing: find out if symlink creation is fast on
> >>>>> NFS and GPFS.
> >>>>> Is another approach to copy direct from the user's files to the /tmp
> >>>>> workdir (ie wrapper.sh pulls the data in)? Measurement will tell if
> >>>>> symlinks alone get adequate performance. Symlinks do seem an easier
> >>>>> first step.
> >>>>>> I think option ii) is substantially easier to implement (on the
> >>>>>> order of days) and is generally useful in the single-cluster,
> >>>>>> local-source-data situation that appears to be what people want to
> >>>>>> do for running on the BG/P and scicortex (that is, pretty much
> >>>>>> ignoring anything grid-like at all).
> >>>>> Grid-like might mean pulling data to the /tmp workdir directly by
> >>>>> the wrapper - but that seems like a harder step, and would need
> >>>>> measurement and prototyping of such code before attempting. Data
> >>>>> transfer clients that the wrapper script can count on might be an
> >>>>> obstacle.
> >>>>>> Option i) is much harder (on the order of months), needing a very
> >>>>>> different interface between Swift and Falkon than exists at the
> >>>>>> moment.
> >> _______________________________________________
> >> Swift-devel mailing list
> >> Swift-devel at ci.uchicago.edu
> >> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
> Ioan Raicu
> Ph.D. Candidate
> Distributed Systems Laboratory
> Computer Science Department
> University of Chicago
> 1100 E. 58th Street, Ryerson Hall
> Chicago, IL 60637
> Email: iraicu at cs.uchicago.edu
> Web:   http://www.cs.uchicago.edu/~iraicu
> http://dev.globus.org/wiki/Incubator/Falkon
> http://dsl-wiki.cs.uchicago.edu/index.php/Main_Page
