[Swift-devel] SSH support
    Michael Wilde
    wilde at mcs.anl.gov
    Thu Apr 10 07:55:06 CDT 2008
Ooops, I have a typo in my sites file - I fixed it but must have saved
into wrong place. Let me re-test before you look into this. Sorry.
- Mike
On 4/10/08 7:31 AM, Michael Wilde wrote:
> I just tried this for the first time and I cant get it to work, Mihael.
> Can you take a look?
> I get these errors:
> 2008-04-09 23:04:47,221-0500 DEBUG TaskImpl Task(type=FILE_OPERATION,
> identity=urn:0-1207800286502) setting status to Failed
> org.globus.cog.abstraction.impl.file.FileResourceException: Error while
> communi\
> cating with the SSH server on login.ci.uchicago.edu:22
> Could not initialize shared directory on login.ci
> Caused by: org.globus.cog.abstraction.impl.file.FileResourceException:
> Error while communicating with the SSH server on login.ci.uchicago.edu:22
> Caused by:
> org.globus.cog.abstraction.impl.common.task.TaskSubmissionException:
> communicating with the SSH server on login.ci.uchica\
> go.edu:22
> Caused by: java.lang.NullPointerException
> All the related files and logs are in ~benc/swift/logs/wilde/run354
> Im running swift on terminable, with a 1-job test workflow to login.ci.
> I created a new rsa key, with a passphrase, and added it to
> authorized-keys. I tested the key and can manually ssh to login.ci from
> terminable with it, and verified the passphrase. (see file keytest)
> Also, once we have this working, can I eliminate the passphrase from
> auth.defaults if I use an agent?
> Thanks,
> - Mike
> On 11/23/07 3:42 PM, Mihael Hategan wrote:
>> I've updated the SSH provider in cog to do a few things:
>> - make better use of connections (cache them). SSH has this nifty thing:
>> On one connection you can configure multiple independent channels
>> (OpenSSH servers seem to support up to 10 such channels per connection).
>> With this you get up to 10 independent shells without authenticating
>> again.
>> - access remote filesystems (a file op provider) with SFTP
>> - get default authentication information from a file
>> (~/.ssh/auth.defaults). I attached a sample. I need to document this.
>> I also added a filesystem element in the site catalog, which works in a
>> similar way to the execution element:
>>  <pool handle="plussed" sysinfo="INTEL32::LINUX">
>>     <filesystem provider="ssh" url="plussed.mcs.anl.gov"
>> storage="/homes/hategan/tmp" />
>>     <execution provider="ssh" url="plussed.mcs.anl.gov" />
>>     <workdirectory>/homes/hategan/tmp</workdirectory>
>>   </pool>
>> That basically allows Swift to work with SSH.
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
