[Swift-devel] SSH support
Michael Wilde
wilde at mcs.anl.gov
Thu Apr 10 07:31:51 CDT 2008
I just tried this for the first time and I cant get it to work, Mihael.
Can you take a look?
I get these errors:
2008-04-09 23:04:47,221-0500 DEBUG TaskImpl Task(type=FILE_OPERATION,
identity=urn:0-1207800286502) setting status to Failed
org.globus.cog.abstraction.impl.file.FileResourceException: Error while
communi\
cating with the SSH server on login.ci.uchicago.edu:22
Could not initialize shared directory on login.ci
Caused by: org.globus.cog.abstraction.impl.file.FileResourceException:
Error while communicating with the SSH server on login.ci.uchicago.edu:22
Caused by:
org.globus.cog.abstraction.impl.common.task.TaskSubmissionException:
communicating with the SSH server on login.ci.uchica\
go.edu:22
Caused by: java.lang.NullPointerException
All the related files and logs are in ~benc/swift/logs/wilde/run354
Im running swift on terminable, with a 1-job test workflow to login.ci.
I created a new rsa key, with a passphrase, and added it to
authorized-keys. I tested the key and can manually ssh to login.ci from
terminable with it, and verified the passphrase. (see file keytest)
Also, once we have this working, can I eliminate the passphrase from
auth.defaults if I use an agent?
- Mike
On 11/23/07 3:42 PM, Mihael Hategan wrote:
> I've updated the SSH provider in cog to do a few things:
> - make better use of connections (cache them). SSH has this nifty thing:
> On one connection you can configure multiple independent channels
> (OpenSSH servers seem to support up to 10 such channels per connection).
> With this you get up to 10 independent shells without authenticating
> again.
> - access remote filesystems (a file op provider) with SFTP
> - get default authentication information from a file
> (~/.ssh/auth.defaults). I attached a sample. I need to document this.
> I also added a filesystem element in the site catalog, which works in a
> similar way to the execution element:
> <pool handle="plussed" sysinfo="INTEL32::LINUX">
> <filesystem provider="ssh" url="plussed.mcs.anl.gov"
> storage="/homes/hategan/tmp" />
> <execution provider="ssh" url="plussed.mcs.anl.gov" />
> <workdirectory>/homes/hategan/tmp</workdirectory>
> </pool>
> That basically allows Swift to work with SSH.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
