[Swift-devel] Re: cog r1957 breaks swift ftp usage (when port not specified?)
Mihael Hategan hategan at mcs.anl.gov
Tue Apr 8 06:21:15 CDT 2008
Ok. Try r1962.
On Tue, 2008-04-08 at 06:10 -0500, Mihael Hategan wrote:
> Grr!
> Fix coming up.
> On Tue, 2008-04-08 at 10:01 +0000, Ben Clifford wrote:
> > CoG r1957 appears to break handling of gsiftp URLs specified in the Swift
> > site catalog.
> > All of the site tests in
> > https://svn.ci.uchicago.edu/svn/vdl2/trunk/tests/sites are configured that
> > way and are broken by r1957.
> > When I apply svn diff -r 1957:1956 to my checkout, things work better (I
> > ran the site tests on a few of the sites, but not all as I got tired of
> > waiting)
> > First part of stack trace is:
> > Using sites file: ../sites/tp-fork-gram2-ftpport.xml
> > Using tc.data: ../sites/tc.data
> > For input string: ""
> >         task:service @ vdl-sc.k, line: 23
> >         sys:if @ vdl-sc.k, line: 21
> >         gridftp @ tp-fork-gram2-ftpport.xml, line: 4
> >         pool @ tp-fork-gram2-ftpport.xml, line: 4
> >         org.globus.cog.karajan.workflow.nodes.Sequential @
> >         sys:executefile @ vdl-sc.k, line: 59
> >         task:resources @ vdl-sc.k, line: 59
> >         vdl:sitecatalog @ scheduler.xml, line: 42
> >         task:scheduler @ scheduler.xml, line: 27
> >         kernel:import @ scheduler.xml, line: 3
> >         kernel:project @ 061-cattwo.kml, line: 2
> >         061-cattwo-20080408-1100-eibujbf8
> > Caused by: java.lang.NumberFormatException: For input string: ""
> >         at
> > java.lang.NumberFormatException.forInputString(NumberFormatException.java:48)
> >         at java.lang.Integer.parseInt(Integer.java:468)
> >         at java.lang.Integer.parseInt(Integer.java:497)
> >         at
> > org.globus.cog.abstraction.impl.common.task.ServiceContactImpl.parse(ServiceContactImpl.java:81)
> >         at
> > org.globus.cog.abstraction.impl.common.task.ServiceContactImpl.<init>(ServiceContactImpl.java:26)
> >         at
> > org.globus.cog.karajan.workflow.nodes.grid.ServiceNode.function(ServiceNode.java:123)
> >         at
> > org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:45)
> >         at
> > org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.childCompleted(AbstractSequentialWithArguments.java:192)
> >         at
> > org.globus.cog.karajan.workflow.nodes.Sequential.notificationEvent(Sequential.java:33)
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
