[Swift-devel] Re: cog r1957 breaks swift ftp usage (when port not	specified?)
    Mihael Hategan
    hategan at mcs.anl.gov
    Tue Apr  8 06:10:03 CDT 2008
Grr!
Fix coming up.
On Tue, 2008-04-08 at 10:01 +0000, Ben Clifford wrote:
> CoG r1957 appears to break handling of gsiftp URLs specified in the Swift
> site catalog.
> All of the site tests in
> https://svn.ci.uchicago.edu/svn/vdl2/trunk/tests/sites are configured that
> way and are broken by r1957.
> When I apply svn diff -r 1957:1956 to my checkout, things work better (I
> ran the site tests on a few of the sites, but not all as I got tired of
> waiting)
> First part of stack trace is:
> Using sites file: ../sites/tp-fork-gram2-ftpport.xml
> Using tc.data: ../sites/tc.data
> For input string: ""
>         task:service @ vdl-sc.k, line: 23
>         sys:if @ vdl-sc.k, line: 21
>         gridftp @ tp-fork-gram2-ftpport.xml, line: 4
>         pool @ tp-fork-gram2-ftpport.xml, line: 4
>         org.globus.cog.karajan.workflow.nodes.Sequential @
>         sys:executefile @ vdl-sc.k, line: 59
>         task:resources @ vdl-sc.k, line: 59
>         vdl:sitecatalog @ scheduler.xml, line: 42
>         task:scheduler @ scheduler.xml, line: 27
>         kernel:import @ scheduler.xml, line: 3
>         kernel:project @ 061-cattwo.kml, line: 2
>         061-cattwo-20080408-1100-eibujbf8
> Caused by: java.lang.NumberFormatException: For input string: ""
>         at
> java.lang.NumberFormatException.forInputString(NumberFormatException.java:48)
>         at java.lang.Integer.parseInt(Integer.java:468)
>         at java.lang.Integer.parseInt(Integer.java:497)
>         at
> org.globus.cog.abstraction.impl.common.task.ServiceContactImpl.parse(ServiceContactImpl.java:81)
>         at
> org.globus.cog.abstraction.impl.common.task.ServiceContactImpl.<init>(ServiceContactImpl.java:26)
>         at
> org.globus.cog.karajan.workflow.nodes.grid.ServiceNode.function(ServiceNode.java:123)
>         at
> org.globus.cog.karajan.workflow.nodes.functions.AbstractFunction.post(AbstractFunction.java:45)
>         at
> org.globus.cog.karajan.workflow.nodes.AbstractSequentialWithArguments.childCompleted(AbstractSequentialWithArguments.java:192)
>         at
> org.globus.cog.karajan.workflow.nodes.Sequential.notificationEvent(Sequential.java:33)
