[Swift-devel] Problem calling atomic procedure with multiple args via Falkon
Ioan Raicu iraicu at cs.uchicago.edu
Mon Apr 7 13:19:25 CDT 2008
Mihael Hategan wrote:
>> The problem seems to stem from this arg:
>> -if mol-1M/8269/058269.in|mol-1M/8269/058269.mol2
> I'd say the problem stems from improper passing of the arguments by some
> layer somewhere.
>> The value after the -if arg needs to be in quotes to shield it from the
>> shell, as falkon takes the string and involves wrapper.sh using
>> system().
> ...presumably by concatenating the arguments into a single string and
> hoping system() will split them correctly. Falkon should use execve().
Right... its on the to-do list!
http://bugzilla.globus.org/globus/show_bug.cgi?id=5987
>>  The IFS char "|" is causing the cmd to end there.
>> Its not clear if the arg is not quoted because in other providers its
>> somehow shielded from shell evaluation, or if Falkon or the deef
>> provider is pulling off the quotes.
>> Can anyone spot where the problem is?
>> Swift-devel mailing list
>> Swift-devel at ci.uchicago.edu
>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Ioan Raicu
Ph.D. Candidate
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web:   http://www.cs.uchicago.edu/~iraicu
http://dev.globus.org/wiki/Incubator/Falkon
http://dsl-wiki.cs.uchicago.edu/index.php/Main_Page
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20080407/fe290d01/attachment.html>
