[Swift-devel] Problem calling atomic procedure with multiple args via Falkon
Mihael Hategan hategan at mcs.anl.gov
Mon Apr 7 03:14:23 CDT 2008
> The problem seems to stem from this arg:
> -if mol-1M/8269/058269.in|mol-1M/8269/058269.mol2
I'd say the problem stems from improper passing of the arguments by some
layer somewhere.
> The value after the -if arg needs to be in quotes to shield it from the
> shell, as falkon takes the string and involves wrapper.sh using
> system().
...presumably by concatenating the arguments into a single string and
hoping system() will split them correctly. Falkon should use execve().
>  The IFS char "|" is causing the cmd to end there.
> Its not clear if the arg is not quoted because in other providers its
> somehow shielded from shell evaluation, or if Falkon or the deef
> provider is pulling off the quotes.
> Can anyone spot where the problem is?
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
