[Fwd: Re: [Swift-devel] Re: swift-falkon problem... plots to	explain plateaus...]
    Michael Wilde
    wilde at mcs.anl.gov
    Wed Apr  2 07:21:35 CDT 2008
Im very much in favor of this approach.
- Mike
On 4/1/08 11:11 PM, Ben Clifford wrote:
> On Tue, 1 Apr 2008, Mihael Hategan wrote:
>> Having optimized wrappers for different architectures is a perfectly
>> valid option.
> it might also be possible to replace the entire execute2 layer of
> stagein-execute-stageout if falkon wants to do its own worker-node data
> placement - Swift would be the same down to calling execute2 but the
> execute2-replacement would be falkon specific rather than using the
> present model which assumes a shared filesystem for stageins.
> I think that might fit in better with what Falkon is trying to do, letting
> it know which files are required by which job, rather than assuming a
> cluster-wide shared filesystem to fetch data from.
> (The same might apply for using condor with no shared filesystem, which
> isthe situation in many campus workstation labs that I've seen - an
> execute2 layer that submits a bundled up stagein/stageout/execute as a
> single condor submission - I have been mulling over that for a few months
> and maybe will get someone to play with that in google summer of code)
