[Fwd: Re: [Swift-devel] Re: swift-falkon problem... plots to explain plateaus...]
Ben Clifford
benc at hawaga.org.uk
Tue Apr 1 23:11:23 CDT 2008
On Tue, 1 Apr 2008, Mihael Hategan wrote:
> Having optimized wrappers for different architectures is a perfectly
> valid option.
it might also be possible to replace the entire execute2 layer of
stagein-execute-stageout if falkon wants to do its own worker-node data
placement - Swift would be the same down to calling execute2 but the
execute2-replacement would be falkon specific rather than using the
present model which assumes a shared filesystem for stageins.
I think that might fit in better with what Falkon is trying to do, letting
it know which files are required by which job, rather than assuming a
cluster-wide shared filesystem to fetch data from.
(The same might apply for using condor with no shared filesystem, which
isthe situation in many campus workstation labs that I've seen - an
execute2 layer that submits a bundled up stagein/stageout/execute as a
single condor submission - I have been mulling over that for a few months
and maybe will get someone to play with that in google summer of code)
