[Swift-devel] .backup files in SVN and case conflicts (fwd)
    Ioan Raicu
    iraicu at cs.uchicago.edu
    Fri Sep 21 14:38:30 CDT 2007
OK, I updated the clean-falkon.sh and make-falkon.sh to use ant...
Ioan
Veronika Nefedova wrote:
> README.SVN tells to do ./make-falcon.sh.
> On Sep 21, 2007, at 2:15 PM, Ioan Raicu wrote:
>> Did you do:
>> cd falkon
>> ant clean
>> ant all
>> The kind of output you have:
>>> Compiling Console.java
>>> Compiling UserRun.java
>>> Note:
>>> org/globus/GenericPortal/clients/GPService_instance/UserRun.java
>>> uses unchecked or unsafe operations.
>>> Note: Recompile with -Xlint:unchecked for details.
>> doesn't look like its from ant, but from my regular compile scripts I
>> had prior...
>> if you ran falkon/make-falkon.sh, then that is a bit outdated, and
>> you are not going to get the "BUILD SUCCESSFUL" as its not running
>> through ant.
>> OK, so try ant all, and I bet you are going to see the successful
>> message at the end.
>> Ioan
>>> Nope. What I sent you below was the very last stdout I had after the
>>> compile. No 'BUILD SUCCESSFUL" - thus I decided to check with you...
>>> I am at r1256
>>> Nika
>>> On Sep 21, 2007, at 2:06 PM, Ioan Raicu wrote:
>>>> Those are fine, you can simply ignore them... I need to get them
>>>> out of there, but just hadn't had the time.
>>>> You should see the following (placed ... in places where I omitted
>>>> text) if everything went OK; note that at the very end, there is
>>>> (BUILD SUCCESSFUL, Total time: 45 seconds):
>>>> Ioan
>>>> iraicu at viper:~/java/svn/falkon> ant all
>>>> Buildfile: build.xml
>>>> service:
>>>>     [exec] compiling the GenericPortal...
>>>>     [exec] Buildfile: build-falkon.xml
>>>>     [exec] all:
>>>>     [exec]       [jar] Building jar:
>>>> /home/iraicu/java/svn/falkon/service/org_globus_GenericPortal_common.jar
>>>>     [exec]      [copy] Copying 8 files to
>>>> /home/iraicu/java/svn/falkon/worker/org
>>>>     [exec]      [copy] Copying 38 files to
>>>> /home/iraicu/java/svn/falkon/client/org
>>>>     [exec] BUILD SUCCESSFUL
>>>>     [exec] Total time: 22 seconds
>>>> worker:
>>>>     [exec] update the stubs...
>>>>     [exec] cp: cannot create regular file
>>>> `./schema/.svn/empty-file': Permission denied
>>>>     [exec] compile common stuff
>>>>     [exec] Note: Some input files use or override a deprecated API.
>>>>     [exec] Note: Recompile with -deprecation for details.
>>>>     [exec] Compiling ClientCreate.java
>>>>     [exec] Compiling WorkerRun.java
>>>>     [exec] Compiling WorkerRunGram.java
>>>>     [exec] Compiling GramClient
>>>> client:
>>>>     [exec] Compiling Console.java
>>>>     [exec] Compiling UserRun.java
>>>> all:
>>>> BUILD SUCCESSFUL
>>>>> Ioan, this version is much better!
>>>>> I still get some warnings/errors. Could you please let me know if
>>>>> its ok to ignore them? These are just a few of those  I got:
>>>>> <snip>
>>>>> `./org/globus/GenericPortal/common/.svn/format': Permission denied
>>>>> `./org/globus/GenericPortal/common/.svn/dir-wcprops': Permission
>>>>> denied
>>>>> Note: Recompile with -Xlint:deprecation for details.
>>>>> Note: Some input files use unchecked or unsafe operations.
>>>>> Note:
>>>>> org/globus/GenericPortal/clients/GPService_instance/WorkerRunGram.java
>>>>> Note:
>>>>> On Sep 21, 2007, at 1:24 PM, Ben Clifford wrote:
>>>>>> incremental updates are a bad habit to get into - don't do that.
>>>>>> On Fri, 21 Sep 2007, Ioan Raicu wrote:
>>>>>>> OK, it works for me now! If you want to do incremental updates,
>>>>>>> here they are:
>>>>>>> cd falkon/service/org/globus/GenericPortal/services/core/WS/impl
>>>>>>> svn up
>>>>>>> cd falkon/service/org/globus/GenericPortal/common
>>>>>>> svn up
>>>>>>> falkon/service/schema/GenericPortal/GPService_instance
>>>>>>> svn up
>>>>>>> If not, just do a svn up in the root dir.
>>>>>>> Ioan
>>>>>>> Ben Clifford wrote:
>>>>>>>> I just removed a bunch more backup files - r1253
>>>>>>>> Don't forget to 'svn update' in your checkout.
>>>> Ioan Raicu
>>>> Ph.D. Student
>>>> Distributed Systems Laboratory
>>>> Computer Science Department
>>>> University of Chicago
>>>> 1100 E. 58th Street, Ryerson Hall
>>>> Chicago, IL 60637
>>>> Email: iraicu at cs.uchicago.edu
>>>> Web:   http://www.cs.uchicago.edu/~iraicu
>>>>       http://dsl.cs.uchicago.edu/
>> Ioan Raicu
>> Ph.D. Student
>> Chicago, IL 60637
Ioan Raicu
Ph.D. Student
Chicago, IL 60637
