[Swift-devel] .backup files in SVN and case conflicts (fwd)
    Veronika Nefedova
    nefedova at mcs.anl.gov
    Fri Sep 21 14:28:11 CDT 2007
README.SVN tells to do ./make-falcon.sh.
On Sep 21, 2007, at 2:15 PM, Ioan Raicu wrote:
> Did you do:
> cd falkon
> ant clean
> ant all
> The kind of output you have:
>> Compiling Console.java
>> Compiling UserRun.java
>> Note: org/globus/GenericPortal/clients/GPService_instance/
>> UserRun.java uses unchecked or unsafe operations.
>> Note: Recompile with -Xlint:unchecked for details.
> doesn't look like its from ant, but from my regular compile scripts
> I had prior...
> if you ran falkon/make-falkon.sh, then that is a bit outdated, and
> you are not going to get the "BUILD SUCCESSFUL" as its not running
> through ant.
> OK, so try ant all, and I bet you are going to see the successful
> message at the end.
> Ioan
> Veronika Nefedova wrote:
>> Nope. What I sent you below was the very last stdout I had after
>> the compile. No 'BUILD SUCCESSFUL" - thus I decided to check with
>> you...
>> I am at r1256
>> Nika
>> On Sep 21, 2007, at 2:06 PM, Ioan Raicu wrote:
>>> Those are fine, you can simply ignore them... I need to get them
>>> out of there, but just hadn't had the time.
>>> You should see the following (placed ... in places where I
>>> omitted text) if everything went OK; note that at the very end,
>>> there is (BUILD SUCCESSFUL, Total time: 45 seconds):
>>> Ioan
>>> iraicu at viper:~/java/svn/falkon> ant all
>>> Buildfile: build.xml
>>> service:
>>>     [exec] compiling the GenericPortal...
>>>     [exec] Buildfile: build-falkon.xml
>>>     [exec] all:
>>>     [exec]       [jar] Building jar: /home/iraicu/java/svn/falkon/
>>> service/org_globus_GenericPortal_common.jar
>>>     [exec]      [copy] Copying 8 files to /home/iraicu/java/svn/
>>> falkon/worker/org
>>>     [exec]      [copy] Copying 38 files to /home/iraicu/java/svn/
>>> falkon/client/org
>>>     [exec] BUILD SUCCESSFUL
>>>     [exec] Total time: 22 seconds
>>> worker:
>>>     [exec] update the stubs...
>>>     [exec] cp: cannot create regular file `./schema/.svn/empty-
>>> file': Permission denied
>>>     [exec] compile common stuff
>>>     [exec] Note: Some input files use or override a deprecated API.
>>>     [exec] Note: Recompile with -deprecation for details.
>>>     [exec] Compiling ClientCreate.java
>>>     [exec] Compiling WorkerRun.java
>>>     [exec] Compiling WorkerRunGram.java
>>>     [exec] Compiling GramClient
>>> client:
>>>     [exec] Compiling Console.java
>>>     [exec] Compiling UserRun.java
>>> all:
>>> BUILD SUCCESSFUL
>>>> Ioan, this version is much better!
>>>> I still get some warnings/errors. Could you please let me know
>>>> if its ok to ignore them? These are just a few of those  I got:
>>>> <snip>
>>>> cp: cannot create regular file `./org/globus/GenericPortal/
>>>> common/.svn/format': Permission denied
>>>> common/.svn/dir-wcprops': Permission denied
>>>> Note: Recompile with -Xlint:deprecation for details.
>>>> Note: Some input files use unchecked or unsafe operations.
>>>> WorkerRunGram.java uses unchecked or unsafe operations.
>>>> On Sep 21, 2007, at 1:24 PM, Ben Clifford wrote:
>>>>> incremental updates are a bad habit to get into - don't do that.
>>>>> On Fri, 21 Sep 2007, Ioan Raicu wrote:
>>>>>> OK, it works for me now! If you want to do incremental
>>>>>> updates, here they are:
>>>>>> cd falkon/service/org/globus/GenericPortal/services/core/WS/impl
>>>>>> svn up
>>>>>> cd falkon/service/org/globus/GenericPortal/common
>>>>>> svn up
>>>>>> falkon/service/schema/GenericPortal/GPService_instance
>>>>>> svn up
>>>>>> If not, just do a svn up in the root dir.
>>>>>> Ioan
>>>>>> Ben Clifford wrote:
>>>>>>> I just removed a bunch more backup files - r1253
>>>>>>> Don't forget to 'svn update' in your checkout.
>>> Ioan Raicu
>>> Ph.D. Student
>>> Distributed Systems Laboratory
>>> Computer Science Department
>>> University of Chicago
>>> 1100 E. 58th Street, Ryerson Hall
>>> Chicago, IL 60637
>>> Email: iraicu at cs.uchicago.edu
>>> Web:   http://www.cs.uchicago.edu/~iraicu
>>>       http://dsl.cs.uchicago.edu/
> Ioan Raicu
> Ph.D. Student
> Chicago, IL 60637
