[Swift-devel] .backup files in SVN and case conflicts (fwd)
Ioan Raicu iraicu at cs.uchicago.edu
Fri Sep 21 11:35:53 CDT 2007
I simply did an add of the entire directory... sorry that backup file
got in there... I haven't really tested any of the monitor code lately
since the integration, so none of that stuff in monitor is really finalized.
Ioan
Ben Clifford wrote:
> meant to send this to list too - i know nika is playing with falkon
> checkouts at the moment too.
> ---------- Forwarded message ----------
> Date: Fri, 21 Sep 2007 16:26:36 +0000 (GMT)
> From: Ben Clifford <benc at hawaga.org.uk>
> To: iraicu at cs.uchicago.edu
> Subject: .backup files in SVN and case conflicts
> Hi.
> I just removed (in r1251) two files, GRAMClient.java.backup and
> GramClient.java.backup from falkon/monitor/org/globus/GenericPortal/common
> Two files with the same name modulo case breaks checkouts on case
> sensitive filesystems.
> I notice you added these in your recent round of commits. You shouldn't
> put backup files in version control - the version control *is* the backup.
> You can retrieve any arbitrary previous revision of any file from the
> command line or from the web UI.
Ioan Raicu
Ph.D. Student
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web:   http://www.cs.uchicago.edu/~iraicu
       http://dsl.cs.uchicago.edu/
