[Swift-devel] .backup files in SVN and case conflicts (fwd)
Ben Clifford
benc at hawaga.org.uk
Fri Sep 21 11:27:12 CDT 2007
meant to send this to list too - i know nika is playing with falkon
checkouts at the moment too.
---------- Forwarded message ----------
Date: Fri, 21 Sep 2007 16:26:36 +0000 (GMT)
To: iraicu at cs.uchicago.edu
Subject: .backup files in SVN and case conflicts
Hi.
I just removed (in r1251) two files, GRAMClient.java.backup and
GramClient.java.backup from falkon/monitor/org/globus/GenericPortal/common
Two files with the same name modulo case breaks checkouts on case
sensitive filesystems.
I notice you added these in your recent round of commits. You shouldn't
put backup files in version control - the version control *is* the backup.
You can retrieve any arbitrary previous revision of any file from the
command line or from the web UI.
