[Swift-devel] bug 53
    Michael Wilde
    wilde at mcs.anl.gov
    Tue Sep 18 11:39:44 CDT 2007
Did you mean "only for GridFTP"?
See eg:
http://www.globus.org/mail_archive/discuss/2005/02/msg00115.html
- Mike
Mihael Hategan wrote:
> On Tue, 2007-09-18 at 11:01 -0500, Michael Wilde wrote:
>> does the cog equivalent of globus_tcp_source_range also need to be set?
>> is that only for gridftp, or gram as well?  or could this be a gridftp hang?
> That's only for gram. Yes, it can be set. GLOBUS_TCP_SOURCE_PORT_RANGE.
>> - mike
>> Ben Clifford wrote:
>>> can you submit a job using globus-job-run?
>>> On Tue, 18 Sep 2007, Veronika Nefedova wrote:
>>>> I set tcp.port.range in swift properties but even a simple helloworld workflow
>>>> hangs (the  submit host doesn't receive the notification from the compute host
>>>> that the job has finished).
>>>> tcp.port.range=50000,60000
>>>> Not sure what else has changed on viper? It used to be a very good submit
>>>> host, I never had any problems with it );
>>>> Nika
>>>> On Sep 18, 2007, at 9:13 AM, Mihael Hategan wrote:
>>>>> Should pick that one. If not ~/.globus/cog.properties ->
>>>>> tcp.port.range=begin,end
>>>>> On Tue, 2007-09-18 at 07:42 +0000, Ben Clifford wrote:
>>>>>> Not sure if cog picks up the GLOBUS_whatever environment variables. Mihael
>>>>>> presumably knows.
>>>>>> On Mon, 17 Sep 2007, Ioan Raicu wrote:
>>>>>>> There is a firewall on viper.  Ports 50000 - 60000 are open for TCP.
>>>>>>> You
>>>>>>> might want to set the TCP_PORT_RANGE (I am not sure this is the exact
>>>>>>> environment variable, but something like that) to be between 50K and 60K
>>>>>>> ports
>>>>>>> to ensure that GT4 uses one of these open ports.
>>>>>>> Ioan
>>>>>>>> The same. You can check the job's status in its log on viper in
>>>>>>>> ~nefedova/alamines/MolDyn-244-loops-20070917-1356-h95gxij8.log.
>>>>>>>> The job is still runnning (i.e. hanging) with the same symptom as
>>>>>>>> before:
>>>>>>>> the first jobs is done and then nothing else gets submitted (the
>>>>>>>> submit host
>>>>>>>> doesn't receive any notification that the job has finished).
>>>>>>>> NIka
>>>>>>>> On Sep 17, 2007, at 9:51 AM, Mihael Hategan wrote:
>>>>>>>>> On Mon, 2007-09-17 at 09:41 -0500, Veronika Nefedova wrote:
>>>>>>>>>> I did 'svn up' in cog directory and then did 'ant dist' in the
>>>>>>>>>> same
>>>>>>>>>> directory.
>>>>>>>>> 'ant dist' should be done in the swift directory.
>>>>>>>>>> My 'svn info' gives me r1740.
>>>>>>>>>> On Sep 17, 2007, at 8:55 AM, Mihael Hategan wrote:
>>>>>>>>>>> Did you update cog?
>>>>>>>>>>> On Mon, 2007-09-17 at 08:38 -0500, Veronika Nefedova wrote:
>>>>>>>>>>>> No, I've tried with r1740, it still hanged (timed out).
>>>>>>>>>>>> the log is on viper:/home/nefedova/alamines/MolDyn-244-
>>>>>>>>>>>> loops-20070914-1834-pvhyji75.log
>>>>>>>>>>>> NIka
>>>>>>>>>>>> On Sep 15, 2007, at 10:59 AM, Mihael Hategan wrote:
>>>>>>>>>>>>> On Sat, 2007-09-15 at 09:06 +0000, Ben Clifford wrote:
>>>>>>>>>>>>>> On Fri, 14 Sep 2007, Mihael Hategan wrote:
>>>>>>>>>>>>>>> On Thu, 2007-09-13 at 16:41 -0500, Mihael Hategan wrote:
>>>>>>>>>>>>>>>> Ok, so there's something in.
>>>>>>>>>>>>>>> That something was throttling a bit too much (not just
>>>>>>>>>>>>>>> jobs,
>>>>>>>>>>>>>>> but all
>>>>>>>>>>>>>>> tasks on that site). I need to take a second look at it.
>>>>>>>>>>>>>> Is that fixed by cog r1740? It looks like that commit is
>>>>>>>>>>>>>> intended to.
>>>>>>>>>>>>> It's an attempt to fix it, but it needs to be confirmed by
>>>>>>>>>>>>> Nika.
>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>> Swift-devel mailing list
>>>>>>>>>>>>> Swift-devel at ci.uchicago.edu
>>>>>>>>>>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
