[Swift-devel] bug 53
    Mihael Hategan
    hategan at mcs.anl.gov
    Tue Sep 18 11:29:31 CDT 2007
On Tue, 2007-09-18 at 11:01 -0500, Michael Wilde wrote:
> does the cog equivalent of globus_tcp_source_range also need to be set?
> is that only for gridftp, or gram as well?  or could this be a gridftp hang?
That's only for gram. Yes, it can be set. GLOBUS_TCP_SOURCE_PORT_RANGE.
> - mike
> Ben Clifford wrote:
> > can you submit a job using globus-job-run?
> > On Tue, 18 Sep 2007, Veronika Nefedova wrote:
> >> I set tcp.port.range in swift properties but even a simple helloworld workflow
> >> hangs (the  submit host doesn't receive the notification from the compute host
> >> that the job has finished).
> >> tcp.port.range=50000,60000
> >> Not sure what else has changed on viper? It used to be a very good submit
> >> host, I never had any problems with it );
> >> Nika
> >> On Sep 18, 2007, at 9:13 AM, Mihael Hategan wrote:
> >>> Should pick that one. If not ~/.globus/cog.properties ->
> >>> tcp.port.range=begin,end
> >>> On Tue, 2007-09-18 at 07:42 +0000, Ben Clifford wrote:
> >>>> Not sure if cog picks up the GLOBUS_whatever environment variables. Mihael
> >>>> presumably knows.
> >>>> On Mon, 17 Sep 2007, Ioan Raicu wrote:
> >>>>> There is a firewall on viper.  Ports 50000 - 60000 are open for TCP.
> >>>>> You
> >>>>> might want to set the TCP_PORT_RANGE (I am not sure this is the exact
> >>>>> environment variable, but something like that) to be between 50K and 60K
> >>>>> ports
> >>>>> to ensure that GT4 uses one of these open ports.
> >>>>> Ioan
> >>>>>> The same. You can check the job's status in its log on viper in
> >>>>>> ~nefedova/alamines/MolDyn-244-loops-20070917-1356-h95gxij8.log.
> >>>>>> The job is still runnning (i.e. hanging) with the same symptom as
> >>>>>> before:
> >>>>>> the first jobs is done and then nothing else gets submitted (the
> >>>>>> submit host
> >>>>>> doesn't receive any notification that the job has finished).
> >>>>>> NIka
> >>>>>> On Sep 17, 2007, at 9:51 AM, Mihael Hategan wrote:
> >>>>>>> On Mon, 2007-09-17 at 09:41 -0500, Veronika Nefedova wrote:
> >>>>>>>> I did 'svn up' in cog directory and then did 'ant dist' in the
> >>>>>>>> same
> >>>>>>>> directory.
> >>>>>>> 'ant dist' should be done in the swift directory.
> >>>>>>>> My 'svn info' gives me r1740.
> >>>>>>>> On Sep 17, 2007, at 8:55 AM, Mihael Hategan wrote:
> >>>>>>>>> Did you update cog?
> >>>>>>>>> On Mon, 2007-09-17 at 08:38 -0500, Veronika Nefedova wrote:
> >>>>>>>>>> No, I've tried with r1740, it still hanged (timed out).
> >>>>>>>>>> the log is on viper:/home/nefedova/alamines/MolDyn-244-
> >>>>>>>>>> loops-20070914-1834-pvhyji75.log
> >>>>>>>>>> NIka
> >>>>>>>>>> On Sep 15, 2007, at 10:59 AM, Mihael Hategan wrote:
> >>>>>>>>>>> On Sat, 2007-09-15 at 09:06 +0000, Ben Clifford wrote:
> >>>>>>>>>>>> On Fri, 14 Sep 2007, Mihael Hategan wrote:
> >>>>>>>>>>>>> On Thu, 2007-09-13 at 16:41 -0500, Mihael Hategan wrote:
> >>>>>>>>>>>>>> Ok, so there's something in.
> >>>>>>>>>>>>> That something was throttling a bit too much (not just
> >>>>>>>>>>>>> jobs,
> >>>>>>>>>>>>> but all
> >>>>>>>>>>>>> tasks on that site). I need to take a second look at it.
> >>>>>>>>>>>> Is that fixed by cog r1740? It looks like that commit is
> >>>>>>>>>>>> intended to.
> >>>>>>>>>>> It's an attempt to fix it, but it needs to be confirmed by
> >>>>>>>>>>> Nika.
> >>>>>>>>>>> _______________________________________________
> >>>>>>>>>>> Swift-devel mailing list
> >>>>>>>>>>> Swift-devel at ci.uchicago.edu
> >>>>>>>>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
