[Swift-devel] Re: Kickstart
    Brian Tierney
    bltierney at lbl.gov
    Thu Sep 13 09:00:47 CDT 2007
Its important to us to be compatible with syslog, so newlines are not
allowed.
You can talk to Stu or Martin to see how they handled this for WS-GRAM.
Mihael Hategan wrote:
> That doesn't sound quite right. I somewhat doubt a logging format will
> get wide adoption if it does not adapt to the realities of the software
> it tries to service. Perhaps there is a way to reconcile things?
> Mihael
> On Wed, 2007-09-12 at 21:43 -0700, Dan Gunter wrote:
>> Newlines would be replaced with some other allowed character(s).
>> -Dan
>>> So how would a java exception (being a multi-line thing) be logged in
>>> this format?
>>> Mihael
>>> On Wed, 2007-09-12 at 16:35 -0500, Michael Wilde wrote:
>>>> Dan, sounds good.  As a GRAM and GridFTP client (using CoG interfaces)
>>>> how would Swift (or Karajan, which Swift calls) insert these identifiers?
>>>> (I'll step aside and let Mihael pick the discussion up with you when
>>>> time permits - he's the developer of all layers of code involved from
>>>> CoG up, and would know all the details).
>>>> - Mike
>>>> Dan Gunter wrote:
>>>>> Hi,
>>>>> We (CEDPS) have prototype code to load logs, using a simple mapping of
>>>>> one event type to one table, into a relational DB (MySQL, Postgres,
>>>>> SQLite). We could use this as a starting point for some of the analysis.
>>>>> One of the issues that comes up immediately is how to know which events
>>>>> belong to which workflow. Any help kickstart could provide w.r.t.
>>>>> inserting common identifiers would ease the correlation task down the line..
>>>>> -Dan
>>>>>> Hi Brian,
>>>>>> Lets continue this informally in email. Perhaps Ben (Swift Tech
>>>>>> Coordinator) can join one of the calls.
>>>>>> It will be pretty simple to get kickstart data in the right form.
>>>>>> But an intersting and perhaps valuable (dare I say exciting?) demo of
>>>>>> logging would be to do a multi-site workflow, and correlate all he
>>>>>> logs from GRAM, GridFTP, and Swift, into a meaningful ans useful
>>>>>> stream; then do queries/reports on that stream.
>>>>>> I'm cc'ing the Swift devel list to encourage discussion, but I think
>>>>>> we can make small continuos steps in this direction and make something
>>>>>> interesting happen pretty readily.
>>>>>> What would we need to do to get CEDPS-conformant logging from GRAM &
>>>>>> GridFTP at the sites we frequent? (the CI's TeraPort, uc-teragrid, and
>>>>>> tg sites at ncsa, sdsc, purdue, tacc, perhaps a few more?)  Plus OSG
>>>>>> sites as we start using them more?
>>>>>> - Mike
>>>>>> Brian Tierney wrote:
>>>>>>> Mike:
>>>>>>> After reading the Kickstart paper, I think there are several possible
>>>>>>> areas of collaboration with CEDPS.
>>>>>>> Do you want to talk about this on one of the CEDPS calls, or perhaps
>>>>>>> better would be to discuss this in person when we are at ANL for the
>>>>>>> CEDPS meeting at the end of October.
>>>>>>> Thoughts?
>>>> _______________________________________________
>>>> Swift-devel mailing list
>>>> Swift-devel at ci.uchicago.edu
>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
   Brian L. Tierney,   Lawrence Berkeley National Laboratory (LBNL)
   1 Cyclotron Rd.  MS: 50B-2239,  Berkeley, CA  94720
   tel: 510-486-7381    fax: 510-495-2998   efax: 425-642-4558
   bltierney at lbl.gov   http://www-didc.lbl.gov/~tierney
