[Swift-devel] running MolDyn...
Cătălin L. Dumitrescu
catalind at cs.uchicago.edu
Sun Sep 9 08:26:07 CDT 2007
There is also an error in the wrapper.sh script on line 84 (if I remember
correctly). The line is: $EXITCODE=-128 and generates strage error in Falkon
when running. It should be just EXITCODE=-128, of course.
./modules/vdsk/dist/vdsk-0.2-dev/libexec/wrapper.sh
./modules/vdsk/libexec/wrapper.sh
On Friday 07 September 2007 11:02:55 am Ioan Raicu wrote:
| Right! I do have scripts that I source before running Swift, but the
| classpath was set from another GT4 install I have on the same system at
| login. I'll cleanup my environment variables. Thanks again.
| Ioan
| Ben Clifford wrote:
| > On Fri, 7 Sep 2007, Ioan Raicu wrote:
| >> Alright, it works! I had to unset my CLASSPATH, I guess it was picking
| >> up some older version of the stubs from elsewhere...
| > You might find some more classpath hygene is helpful here: don't have any
| > classpath set at login. Have a small set of scripts that you can source
| > to configure your classpath for any particular environment. Never switch
| > environments in the same shell - log out and start a new one if you want
| > to switch.
Thanks & Regards!
___________________________________________
http://people.cs.uchicago.edu/~cldumitr
