[Swift-devel] running MolDyn...
    Ioan Raicu
    iraicu at cs.uchicago.edu
    Fri Sep  7 11:02:55 CDT 2007
Right!  I do have scripts that I source before running Swift, but the
classpath was set from another GT4 install I have on the same system at
login.  I'll cleanup my environment variables.  Thanks again.
Ioan
Ben Clifford wrote:
> On Fri, 7 Sep 2007, Ioan Raicu wrote:
>> Alright, it works!  I had to unset my CLASSPATH, I guess it was picking up
>> some older version of the stubs from elsewhere...
> You might find some more classpath hygene is helpful here: don't have any
> classpath set at login. Have a small set of scripts that you can source to
> configure your classpath for any particular environment. Never switch
> environments in the same shell - log out and start a new one if you want
> to switch.
Ioan Raicu
Ph.D. Student
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web:   http://www.cs.uchicago.edu/~iraicu
       http://dsl.cs.uchicago.edu/
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20070907/1923faef/attachment.html>
