[Swift-devel] running MolDyn...
    Ben Clifford
    benc at hawaga.org.uk
    Sun Sep  9 08:47:21 CDT 2007
so old! it would be nice if you were using stuff that was no more than a
few days old - update your swift and cog checkouts more regularly!
On Sun, 9 Sep 2007, Ioan Raicu wrote:
> We are using Revision: 1047 from August 1st, 07.  We'll try updating...
> Ioan
> Ben Clifford wrote:
> > There's nothing in the head version on wrapper.sh (last change r1183 as of
> > r1204) that sets EXITCODE to anything. Can you try a more recent version of
> > the code?
> > On Sun, 9 Sep 2007, CÄ~CtÄ~Clin L. Dumitrescu wrote:
> > >   There is also an error in the wrapper.sh script on line 84 (if I
> > > remember correctly). The line is: $EXITCODE=-128 and generates strage
> > > error in Falkon when running. It should be just EXITCODE=-128, of course.
> > > ./modules/vdsk/dist/vdsk-0.2-dev/libexec/wrapper.sh
> > > ./modules/vdsk/libexec/wrapper.sh
> > > On Friday 07 September 2007 11:02:55 am Ioan Raicu wrote:
> > > | Right!  I do have scripts that I source before running Swift, but the
> > > | classpath was set from another GT4 install I have on the same system at
> > > | login.  I'll cleanup my environment variables.  Thanks again.
> > > | Ioan
> > > | Ben Clifford wrote:
> > > | > On Fri, 7 Sep 2007, Ioan Raicu wrote:
> > > | >> Alright, it works!  I had to unset my CLASSPATH, I guess it was
> > > picking
> > > | >> up some older version of the stubs from elsewhere...
> > > | > You might find some more classpath hygene is helpful here: don't have
> > > any
> > > | > classpath set at login. Have a small set of scripts that you can
> > > source
> > > | > to configure your classpath for any particular environment. Never
> > > switch
> > > | > environments in the same shell - log out and start a new one if you
> > > want
> > > | > to switch.
