[Swift-devel] running MolDyn...
Ioan Raicu
iraicu at cs.uchicago.edu
Sun Sep 9 08:43:07 CDT 2007
We are using Revision: 1047 from August 1st, 07. We'll try updating...
Ioan
Ben Clifford wrote:
> There's nothing in the head version on wrapper.sh (last change r1183 as of
> r1204) that sets EXITCODE to anything. Can you try a more recent version
> of the code?
> On Sun, 9 Sep 2007, CÄ~CtÄ~Clin L. Dumitrescu wrote:
>> There is also an error in the wrapper.sh script on line 84 (if I remember
>> correctly). The line is: $EXITCODE=-128 and generates strage error in Falkon
>> when running. It should be just EXITCODE=-128, of course.
>> ./modules/vdsk/dist/vdsk-0.2-dev/libexec/wrapper.sh
>> ./modules/vdsk/libexec/wrapper.sh
>> On Friday 07 September 2007 11:02:55 am Ioan Raicu wrote:
>> | Right! I do have scripts that I source before running Swift, but the
>> | classpath was set from another GT4 install I have on the same system at
>> | login. I'll cleanup my environment variables. Thanks again.
>> | Ioan
>> | Ben Clifford wrote:
>> | > On Fri, 7 Sep 2007, Ioan Raicu wrote:
>> | >> Alright, it works! I had to unset my CLASSPATH, I guess it was picking
>> | >> up some older version of the stubs from elsewhere...
>> | > You might find some more classpath hygene is helpful here: don't have any
>> | > classpath set at login. Have a small set of scripts that you can source
>> | > to configure your classpath for any particular environment. Never switch
>> | > environments in the same shell - log out and start a new one if you want
>> | > to switch.
Ioan Raicu
Ph.D. Student
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web: http://www.cs.uchicago.edu/~iraicu
http://dsl.cs.uchicago.edu/
