[Swift-devel] detecting providers
    Mihael Hategan
    hategan at mcs.anl.gov
    Wed Sep  5 11:03:14 CDT 2007
On Wed, 2007-09-05 at 15:30 +0000, Ben Clifford wrote:
> On Wed, 5 Sep 2007, Mihael Hategan wrote:
> > Are you getting this too, or are you referring to the error Mike was
> > getting?
> If i give the correct path to my deployment, then the error goes away.
So you were giving it the wrong path.
> Now I get successful execution to falkon, but a log warning and it looks
> like log4j has been overwritten by the provider-deef deploy.
> The ant dist step of provider-deef gives a BUILD SUCCESFUL message on my
> machine when told the wrong path
There's nothing, besides your intent, that tells this that it was the
wrong path.
>  - it happily makes that directory and
> deploys there. That's somewhat fragile behaviour given the intended use of
> provider-deef.
Also perfectly reasonable behavior in other cases.
