[Swift-devel] Clustering / wrapper.sh logging
    Ben Clifford
    benc at hawaga.org.uk
    Mon Oct 29 11:41:32 CDT 2007
Don't mess round in that directory too much, though - every time you do an
ls, you're peturbing pretty much what it is that I'm trying to get
measurements for.
On Mon, 29 Oct 2007, Andrew Robert Jamieson wrote:
> Mike suggested I point folks who are interested to the dir on Teraport where
> this run is taking place now collecting data on the problem. This is an
> example of the 6 hour long WF in reality, which should only take 20 mins or
> so.
> On Teraport:
> /home/andrewj/scratch/SWIFT/Windowlicker-20071029-1043-1zhh40ob
> Notice, if one does an "ls" it lags quite a bit. Also notice the number of
> jobs I have in the queue at the moment (both running and waiting).
> Thanks,
> Andrew
> On Mon, 29 Oct 2007, Ben Clifford wrote:
> > On Mon, 29 Oct 2007, Michael Wilde wrote:
> > > Should Andrew re-run a few good-sized workflows to generate info/ dirs
> > > with
> > > timestamps, so we can zero in on the operation(s) that are taking the most
> > > time?
> > A workflow of the size that was showing the suspect symptoms before would
> > be good.
