[Swift-devel] excessive rate throttling for apparently temporally-restricted failures
Ioan Raicu iraicu at cs.uchicago.edu
Mon Oct 29 00:02:23 CDT 2007
One thing that I noticed is that the site score is quick to react to
failed jobs, but slow to react to successful jobs, to the point that
things take a long time to recover once some rough waters were
encountered. Using the car analogy from below, it would be like coming
to a downward slope where the cruise control adjusts the throttle
position from say 25% to 5% while on the downward slope, but then when
it gets back on flat ground, not going back to 25% for a long time due
to the previous downward slope.  Basically, I think the algorithm memory
might need some tunning, maybe using a window based memory (as opposed
to the entire history of memory), or perhaps give higher weight to more
recent events, weight events according to their execution times, reward
more successive good jobs to allow the system to get back a high score
faster if jobs keep completing successfully, etc...  certainly lots of
things to try out!
Mihael Hategan wrote:
> For some reason this quote from that article seems particularily
> relevant (in that it shows how similar the problem is):
> A simple way to implement cruise control is to lock the throttle
> position when the driver engages cruise control. However, on hilly
> terrain, the vehicle will slow down going uphill and accelerate going
> downhill. This type of controller is called an open-loop controller
> because there is no direct connection between the output of the system
> (the engine torque) and its input (the throttle position).
> In a closed-loop control system, a feedback controller monitors the
> output (the vehicle's speed) and adjusts the control input (the
> throttle) as necessary to keep the control error to a minimum (to
> maintain the desired speed). This feedback dynamically compensates for
> disturbances to the system, such as changes in slope of the ground or
> wind speed.
> On Sun, 2007-10-28 at 22:48 -0500, Ioan Raicu wrote:
>> Right, I now remember reading that... too many emails, and our
>> discussion got side-tracked :)
>> Thanks for the control theory link, it looks like a good read!
>> Ioan
>>> On Sun, 2007-10-28 at 22:41 -0500, Ioan Raicu wrote:
>>>> If the knobs are all there, then I don't think there is an issue at
>>>> the moment.  I think this all started by Ben saying that there was
>>>> excessive throttling due to the site scoring.  Understanding how to
>>>> fix the site scoring is one thing.  Being able to disable site scoring
>>>> is another, which seems to be there already.  Ben, can you turn site
>>>> scoring off, and see if that solves your problem for now?
>>> You can re-read Ben's earlier answer to your same question. I'll post it
>>> here:
>>>> I know how to disable it. I don't particularly want it running rate free.
>>>> Whats happening here is that the feedback loop feeding back too much / too
>>>> fast for the situation I experience.
>>>> There's plenty of fun to be had experimenting there; and I suspect there
>>>> will be no One True Rate Controller.
>> Ioan Raicu
>> Ph.D. Student
>> Distributed Systems Laboratory
>> Computer Science Department
>> University of Chicago
>> 1100 E. 58th Street, Ryerson Hall
>> Chicago, IL 60637
>> Email: iraicu at cs.uchicago.edu
>> Web:   http://www.cs.uchicago.edu/~iraicu
>>        http://dsl.cs.uchicago.edu/
Ioan Raicu
Ph.D. Student
Chicago, IL 60637
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20071029/881b7b49/attachment.html>
