[Swift-devel] Re: Swift Error!
    Michael Wilde
    wilde at mcs.anl.gov
    Wed Oct 10 12:44:34 CDT 2007
You should try a test of everything running on localhost, with the
smallest possible dataset sizes and runtimes (either set your params to
achieve this or replace apps with quick dummies).
This will help ensure that your script has basic data-flow sanity.
as Ben points out, also, if you are going to try readdata you need to
use the 1339 release I sent, or higher.
The instructions to fetch and build the source are on the Download page,
but for now I can post compiled devel snapshots for you, or you can grab
from the nightly builds.
- Mike
On 10/10/07 12:16 PM, andrewj at uchicago.edu wrote:
> Well, I will give it 10 mins, and let you know.
>> none of those messgaes are errors in themselves - they're
> debugging
>> messages about what is going on inside.
>> Do you mean to report that it then hangs 'forever'?
>> On Wed, 10 Oct 2007, andrewj at uchicago.edu wrote:
>>> Hello all,
>>>   I am getting the following to happen when I try to run swift:
>>> [andrewj at terminable Swifty]$ swift -debug 10-10-07-CADWF.swift
>>> 10-10-07-CADWF.swift: source file is new. Recompiling.
>>> Validation of XML intermediate file was successful
>>> Using sites file:
>>> /home/andrewj/CADGrid/Swifty/vdsk-0.3/bin/../etc/sites.xml
>>> Using tc.data:
>>> /home/andrewj/CADGrid/Swifty/vdsk-0.3/bin/../etc/tc.data
>>> Swift v0.3 r1319 (modified locally)
>>> RunID: 20071010-1204-pvgabtv1
>>> Waiting for org.griphyn.vdl.mapping.RootDataNode with no value
>>> at dataset=malFMatrix
>>> at dataset=feature
>>> at dataset=feature
>>> at dataset=feature
>>> You guys are free to look at the swift code located in
>>> /home/andrewj/CADGrid/Swifty/ mounted on the ci disk.
>>> Suggestions?
>>> Thanks,
>>> Andrew
