[Swift-devel] Re: Swift Error!
    andrewj at uchicago.edu
    Wed Oct 10 12:16:31 CDT 2007
Well, I will give it 10 mins, and let you know.
>none of those messgaes are errors in themselves - they're
debugging
>messages about what is going on inside.
>Do you mean to report that it then hangs 'forever'?
>On Wed, 10 Oct 2007, andrewj at uchicago.edu wrote:
>> Hello all,
>>   I am getting the following to happen when I try to run swift:
>> [andrewj at terminable Swifty]$ swift -debug 10-10-07-CADWF.swift
>> 10-10-07-CADWF.swift: source file is new. Recompiling.
>> Validation of XML intermediate file was successful
>> Using sites file:
>> /home/andrewj/CADGrid/Swifty/vdsk-0.3/bin/../etc/sites.xml
>> Using tc.data:
>> /home/andrewj/CADGrid/Swifty/vdsk-0.3/bin/../etc/tc.data
>> Swift v0.3 r1319 (modified locally)
>> RunID: 20071010-1204-pvgabtv1
>> Waiting for org.griphyn.vdl.mapping.RootDataNode with no value
>> at dataset=malFMatrix
>> at dataset=feature
>> at dataset=feature
>> at dataset=feature
>> You guys are free to look at the swift code located in
>> /home/andrewj/CADGrid/Swifty/ mounted on the ci disk.
>> Suggestions?
>> Thanks,
>> Andrew
