[Swift-devel] Problem with @extractint?
Mihael Hategan
hategan at mcs.anl.gov
Tue Oct 9 10:43:38 CDT 2007
On Tue, 2007-10-09 at 10:38 -0500, Michael Wilde wrote:
> If I understood this case right, the data dependencies were logically
> correct but didnt behave so because @extractint() wasnt treated as a
> first-class value. (Mihael, can you clarify, if I got this wrong)
It's what Ben says below.
> I need to gather all my notes, but one point is that in the userguide
> and tutorial, early on, we should document how the data flow model
> works, how its central to swift, and some examples of how it can cause
> program behavior to be "surprising" (eg when the statements in a
> procedure execute in reverse order, or when a statement in a calling
> function executes while a called function is still active, trigerred by
> events in the callee). Until one gets this model, Swift often seems to
> violate the "principle of least astonishment" ;)
> I'll save discussion on this till I get my notes out. I think the model
> is fine, and that we need to better understand how it affects
> programming and how to train users to use it (and debug in it).
> On 10/9/07 9:57 AM, Mihael Hategan wrote:
> > On Tue, 2007-10-09 at 13:22 +0000, Ben Clifford wrote:
> >> The bit of kml that does the assignment is run in a sequential bit that
> >> sets up variables, before any of the parallel stuff happens (that usually
> >> consists of procedure calls, and is the part that ends up being evaluated
> >> in data dependency order rather than source text order).
> >> It makes sense to allow what you want to do, I think.
> > There was some discussion about removing the @ sign in front of built-in
> > functions. There is no need for the distinction, and, apparently, it
> > does cause problems.
