[Swift-devel] Re: passing types and variables in swift
Yong Zhao yongzh at cs.uchicago.edu
Thu Oct 4 22:21:12 CDT 2007
Mappers should ideally be able to map primitive types such as string and
int, as well as file names. The CSVMapper can read all the values in the
file, it is just that it needs to interprete the values according to their
types. So If we convey the type info 'RGIparams' to the csv mapper, it
should have no problem reading the values.
I actually added getType and setType to the mapper interface, that did
not get into the release, but I think it is what it should have.
Yong.
On Thu, 4 Oct 2007 andrewj at uchicago.edu wrote:
> All right, thanks.
> I am just trying to figure out the best way to setup parameter
> sweeps.  Ideally, I would like to have some file of directory
> of files containing experiments to be run on the Grid
> environment and Swift picks them up and automatically sets up
> the appropriate WF based on the parameter information in the
> files.
> >On Wed, 3 Oct 2007, andrewj at uchicago.edu wrote:
> >> could I do something like this:
> >> RGIparams RGIinput[] <csv_mapper;file="rgi_runs.txt">;
> >> where rgi_runs would contain say
> >> 1,2,true
> >> 3,4,false
> >> 18,20,true
> >> and so on..so that the parameters are passed into the workflow?
> >no.
> >mappers only map filenames (or URIs now); they don't map
> variable values.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
