[Swift-devel] Re: passing types and variables in swift
Mihael Hategan hategan at mcs.anl.gov
Thu Oct 4 11:38:19 CDT 2007
These hacks will bite us in the future.
On Thu, 2007-10-04 at 15:46 +0000, Ben Clifford wrote:
> i'd be inclined to grab the csv reading code from the csv mapper and see
> about making a @extractcsv function. It keeps code using it a little bit
> more like it would if mappers could support it, which is probably the way
> things will end up one day.
> On Thu, 4 Oct 2007, Michael Wilde wrote:
> > a hacky way to do this is first a loop to read the csv file into an array,
> > then do a foreach over the array.
> > i suspect we have the constructs (with @extractint) to do this; not sure if we
> > can read the CSV into an array-of-structs that we can then foreach() over. But
> > even if not, this will work using parallel arrays, and probably not be too
> > unpleasing.
> > lets try it.
> > On 10/4/07 10:15 AM, Ben Clifford wrote:
> > > you're the second person today to talk about reading in values from csv
> > > files. maybe we should implement this.
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
