[Swift-devel] slow swift startup time
Michael Wilde wilde at mcs.anl.gov
Mon Nov 5 18:56:45 CST 2007
The lock error I was referring to is this, on stdout/err:
   Failed to acquire exclusive lock on log file.
Below is the log file text that accompanied it.
Note that Im not complaining about this error - it went away when I
started compiling on terminable again.
Im just pointing it out as a suspect in the slow startup. It surprised
me that we bother to lock the logfile, unless Java is gratuituously doig
it for us.
- Mike
Logfile head showed:
2007-11-04 10:15:28,949-0600 INFO  Loader awf3.swift: source file is
new. Recompiling.
2007-11-04 10:15:31,315-0600 INFO  Karajan Validation of XML
intermediate file was successful
2007-11-04 10:15:34,597-0600 INFO  unknown Using sites file: ./sites.xml
2007-11-04 10:15:34,599-0600 INFO  unknown Using tc.data: ./tc.data
2007-11-04 10:15:36,606-0600 INFO  unknown Swift v0.3-dev
libexec/svn-revision: line 1: svn: command not found
2007-11-04 10:15:36,607-0600 INFO  unknown RunID: 20071104-1015-afgc18i3
2007-11-04 10:15:36,825-0600 INFO  AbstractDataNode Found data
pcapfiles.$[]/1.[0]
pcapfiles.$[]/2.[1]
pcapfiles.$[]/3.[2]
pcapfiles.$[]/4.[3]
pcapfiles.$[]/5.[4]
2007-11-04 10:16:26,917-0600 INFO  FlushableLockedFileWriter Could not
acquire lock on /home/wilde/angle/data/./awf3-20071104-1015
-afgc18i3.0.rlog
java.io.IOException: No locks available
         at sun.nio.ch.FileChannelImpl.lock0(Native Method)
         at sun.nio.ch.FileChannelImpl.tryLock(FileChannelImpl.java:804)
         at java.nio.channels.FileChannel.tryLock(FileChannel.java:983)
         at
org.globus.cog.karajan.workflow.nodes.restartLog.FlushableLockedFileWriter.<init>(FlushableLockedFileWriter.java:26)
         at
org.globus.cog.karajan.workflow.nodes.restartLog.RestartLog.create(RestartLog.java:123)
         at
org.globus.cog.karajan.workflow.nodes.restartLog.RestartLog.partialArgumentsEvaluated(RestartLog.java:55)
         at
org.globus.cog.karajan.workflow.nodes.PartialArgumentsContainer.executeChildren(PartialArgumentsContainer.java:51)
         at
org.globus.cog.karajan.workflow.nodes.FlowContainer.execute(FlowContainer.java(Compiled
Code))
         at
org.globus.cog.karajan.workflow.nodes.FlowNode.restart(FlowNode.java(Compiled
Code))
         at
org.globus.cog.karajan.workflow.nodes.FlowNode.start(FlowNode.java(Inlined
Compiled Code))
         at
org.globus.cog.karajan.workflow.nodes.FlowNode.controlEvent(FlowNode.java(Compiled
Code))
         at
org.globus.cog.karajan.workflow.nodes.FlowNode.event(FlowNode.java(Compiled
Code))
         at
org.globus.cog.karajan.workflow.FlowElementWrapper.event(FlowElementWrapper.java(Compiled
Code))
         at
org.globus.cog.karajan.workflow.events.EventBus.send(EventBus.java(Compiled
Code))
         at
org.globus.cog.karajan.workflow.events.EventBus.sendHooked(EventBus.java(Inlined
Compiled Code))
         at
org.globus.cog.karajan.workflow.events.EventWorker.run(EventWorker.java(Compiled
Code))
2007-11-04 10:16:26,921-0600 WARN  RestartLog Failed to acquire
2007-11-04 10:16:26,999-0600 INFO  vdl:execute START thread=0-4 tr=angle4
2007-11-04 10:16:26,999-0600 INFO  vdl:execute START thread=0-1 tr=angle4
2007-11-04 10:16:26,999-0600 INFO  vdl:execute START thread=0-5 tr=angle4
2007-11-04 10:16:27,000-0600 INFO  vdl:execute START thread=0-3 tr=angle4
2007-11-04 10:16:27,001-0600 INFO  vdl:execute START thread=0-2 tr=angle4
On 11/5/07 6:46 PM, Michael Wilde wrote:
> Im running on tg-login.uc.teragrid.org (IA64) and seeing very long swift
> start times.
> My swift command wrapper prints the wf start and end times with the
> swift stdout sandwiched in between.  Here's an example of those,
> followed by the swift log file. In this run, i start swift in the
> background, then tail the stdout file. it was about 70 seconds (on my
> watch) before swift responded with its initial messages on stdout. (I
> dont think its being buffered, but thats worth checking...)
> Note that swift was launched at 18:30:49 and its logfile entry with the
> runid came at 18:32:05.  32:05-30:49 = 76 seconds!
> This was swift 1456 compiled on terminable (or login, i forget).
> Suspicious: when I was running a version compiled in tg-login under Java
> 1.4 I would get an error message from a Java method trying to lock the
> log file. Not sure if this logging action (which now does not give a
> message) is related to this slow start time.
> - Mike
> UC64$ cat swift.out
> Swift Script local-noks.swift starting at Mon Nov 5 18:30:49 CST 2007
> Swift v0.3-dev r1456
> RunID: 20071105-1831-d7t5l2n3
> angle4 started
> angle4 started
> angle4 started
> angle4 started
> angle4 started
> angle4 completed
> angle4 completed
> angle4 completed
> angle4 completed
> angle4 completed
> Swift Script local-noks.swift ended at Mon Nov 5 18:32:34 CST 2007 with
> exit code 0
> UC64$ head awf*.log
> 2007-11-05 18:31:09,566-0600 INFO  Loader awf6.swift: source file is
> new. Recompiling.
> 2007-11-05 18:31:30,454-0600 INFO  Karajan Validation of XML
> 2007-11-05 18:31:55,465-0600 INFO  unknown Using sites file: ./sites.xml
> 2007-11-05 18:31:55,466-0600 INFO  unknown Using tc.data: ./tc.data
> 2007-11-05 18:32:05,518-0600 INFO  unknown Swift v0.3-dev r1456
> 2007-11-05 18:32:05,520-0600 INFO  unknown RunID: 20071105-1831-d7t5l2n3
> 2007-11-05 18:32:06,701-0600 INFO  AbstractDataNode Found data
> pcapfiles.$[]/1.[0]
> 2007-11-05 18:32:06,702-0600 INFO  AbstractDataNode Found data
> pcapfiles.$[]/2.[1]
> pcapfiles.$[]/3.[2]
> UC64$
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
