[Swift-devel] Kickstart runs on localhost are failing
Mihael Hategan hategan at mcs.anl.gov
Sun Nov 4 21:48:21 CST 2007
On Mon, 2007-11-05 at 03:41 +0000, Ben Clifford wrote:
> On Sun, 4 Nov 2007, Mihael Hategan wrote:
> > > Ah, I see. The failure occurs when dealing with kickstart which is after
> > > the files are added to the cache. I did get something wrong.
> > One solution would be to make kickstart transfer failure warnings
> > instead of them being thrown as exceptions (easy).
> > The other would be to only add the stageout files to the cache as the
> > last thing in the execute2 big try block. (very slightly harder).
> I think warnings are preferable.
Done (r1457). I have about 85% confidence that it will work as intended.
