[Swift-devel] Kickstart runs on localhost are failing
Ben Clifford benc at hawaga.org.uk
Sun Nov 4 21:41:20 CST 2007
On Sun, 4 Nov 2007, Mihael Hategan wrote:
> > Ah, I see. The failure occurs when dealing with kickstart which is after
> > the files are added to the cache. I did get something wrong.
> One solution would be to make kickstart transfer failure warnings
> instead of them being thrown as exceptions (easy).
> The other would be to only add the stageout files to the cache as the
> last thing in the execute2 big try block. (very slightly harder).
I think warnings are preferable.
