[Swift-devel] wiring swift and falkon together
    Ben Clifford
    benc at hawaga.org.uk
    Thu May 24 16:31:58 CDT 2007
On Thu, 24 May 2007, Mihael Hategan wrote:
> I'm not sure if that is wise. The falkon provider should be a separate module
> (build entity). In other words, it should be straightforward to either build
> it or not build it.
needs a sensible deployment mechanism then, which pretty much means some
nicer way of plugging in new providers to swift than manually editing
config files / source code each time. there's a feature req for something
like that for plugging in new mappers, but it should cover both.
