[Swift-devel] wiring swift and falkon together
Mihael Hategan
hategan at mcs.anl.gov
Thu May 24 03:49:06 CDT 2007
On 05/23/2007 08:42:26 PM, Ben Clifford wrote:
> so a relatively straightforward thing to do would be to put the source
> code into the swift SVN, put the stubs in jar form into the swift SVN,
> have the falkon provider built as part of the swift build and made
> available for use.
I'm not sure if that is wise. The falkon provider should be a separate
module (build entity). In other words, it should be straightforward to
either build it or not build it.
> another way would be for it to go into cog. but that's for cog to
> decide,
> not me.
It's somewhat unlikely.
> either way looks pretty much the same when swift is deployed.
> how does a user specify that jobs should go through falkon rather than
> the
> other mechanisms?
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
