[Swift-devel] wiring swift and falkon together
Ioan Raicu iraicu at cs.uchicago.edu
Wed May 23 13:14:54 CDT 2007
Ben Clifford wrote:
> What does Falkon deployment look like at the moment? (in terms of
> procedures to deploy it from an empty computer, and in terms of how files
> are laid out, and in terms of how things get configured)?
there is an archive that has everything one might need, a GT4 container,
the service code (which is already deployed in the GT4 container), the
executor code, the client code, and the monitor GUI code.  We also
bundle a 1.4 32bit JRE.  There is a configuration file that points to
where the logs are supposed to go, and another one with what security
mechanisms you want to use.  There are also a bunch of settable
parameters in the startup scripts, and a few obscure setable parameters
in the code, that requires recompiling the service.  To recompile the
service, you need ANT installed and configured as well as 1.4+ JDK; to
recompile anything else, you just need 1.4+ JDK.  With a single script,
and a single arguement (the port number), you can start the entire
Falkon system!
> I think it doesn't make sense to look at the falkon/swift interface code
> without looking at the whole deployment process for both Swift and Falkon
> together.
My understanding is that the Falkon provider can be specified in the
sites.xml, including where the Falkon dispatcher will be found.  Other
than that, everything else should be straight forward.
Ioan
> On Wed, 23 May 2007, Mike Wilde wrote:
>> Im in favor of asking Ioan and possibly Yong - to the extent he has time - to
>> push forward on this, to specifications from Ben and Mihael, and based on
>> usability feedback from Nika and Tibi who need to speak for users' needs.
>> Ben's specs should also address code quality, testing/certification and
>> maintainability.
>> - Mike
>> Tiberiu Stef-Praun wrote, On 5/23/2007 10:57 AM:
>>> It seems that Yong's Falkon provider is working (according to Nika),
>>> so I was wondering when will it make it into the Swift ? At that point
>>> it's more convenient for me to test it (as I would only have to handle
>>> the Falkon backend configuration).
>>> Tibi
>>> On 5/23/07, Ben Clifford <benc at hawaga.org.uk> wrote:
>>>> i hear rumour that its sufficiently unclear how to wire swift and falkon
>>>> together that people are avoiding testing swift code (more recent than the
>>>> 8th of march build that Yong made)
>>>> that is lame - it means large chunks of our app testing are being done
>>>> with code that is 2.5 months old.
>>>> I don't know how Falkon gets deployed alongside swift at the moment, so I
>>>> don't know what to do to make this easier - are they written down
>>>> anywhere?
>>>> _______________________________________________
>>>> Swift-devel mailing list
>>>> Swift-devel at ci.uchicago.edu
>>>> http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Ioan Raicu
Ph.D. Student
Distributed Systems Laboratory
Computer Science Department
University of Chicago
1100 E. 58th Street, Ryerson Hall
Chicago, IL 60637
Email: iraicu at cs.uchicago.edu
Web:   http://www.cs.uchicago.edu/~iraicu
       http://dsl.cs.uchicago.edu/
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20070523/405e4cca/attachment.html>
