[Swift-devel] wiring swift and falkon together
    Tiberiu Stef-Praun
    tiberius at ci.uchicago.edu
    Wed May 23 12:40:24 CDT 2007
So to summarize:
-  apparently there are small changes needed by the Swift's Falcon provider
- will anyone get these in the SVN, and make Swift " Falcon-ready" ?
Note that I did not say "Falcon enabled", because the latter means
that a Falkon service is installed somewhere and ready to run
Tibi
On 5/23/07, Yong Zhao <yongzh at cs.uchicago.edu> wrote:
> Because the Falkon provider code is not in SVN, and that install is where
> you can get the Falkon provider code. But you did update your Swift code
> to the lastest source code in SVN at that time (as you needed some
> new features) as I told you to. So in that sense you were testing at least
> some relative new Swift code.
> Yong.
> On Wed, 23 May 2007, Veronika Nefedova wrote:
> > I think Yong told me to use his swift install from terminable when I
> > started using Falcon. I am not sure why -- I presumed there were some
> > specifics in that install.
> > Nika
> > On May 23, 2007, at 11:36 AM, Ioan Raicu wrote:
> > > Hmmm... from my understanding, the Falkon provider is independent
> > > of the fact that Swift will actually use Falkon or not.  There is
> > > no requirement that Falkon be used, even if you have the Falkon
> > > provider installed!
> > > With that said, our statement about people avoiding the latest
> > > version of Swift due to the Falkon provider doesn't make any sense.
> > > Maybe Yong has more input on this...
> > > About how Falkon gets deplyed, it is simply uncompressed, you
> > > modify 1 or 2 config files, and use the included scripts to start
> > > everything!  All this is in the included readme.txt in the Falkon
> > > archive, downloadable online on my web site.  Once again, if
> > > someone is not intersted in using Falkon, then I see no reason why
> > > they would be doing anything different than before just because
> > > there is now a Falkon provider in Swift.
> > > Ioan
> > > Ben Clifford wrote:
> > >> i hear rumour that its sufficiently unclear how to wire swift and
> > >> falkon together that people are avoiding testing swift code (more
> > >> recent than the 8th of march build that Yong made)
> > >> that is lame - it means large chunks of our app testing are being
> > >> done with code that is 2.5 months old.
> > >> I don't know how Falkon gets deployed alongside swift at the
> > >> moment, so I don't know what to do to make this easier - are they
> > >> written down anywhere?
> > > Ioan Raicu
> > > Ph.D. Student
> > > Distributed Systems Laboratory
> > > Computer Science Department
> > > University of Chicago
> > > 1100 E. 58th Street, Ryerson Hall
> > > Chicago, IL 60637
> > > Email: iraicu at cs.uchicago.edu
> > > Web:   http://www.cs.uchicago.edu/~iraicu
> > >       http://dsl.cs.uchicago.edu/
> > > _______________________________________________
> > > Swift-devel mailing list
> > > Swift-devel at ci.uchicago.edu
> > > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
Tiberiu (Tibi) Stef-Praun, PhD
Research Staff, Computation Institute
5640 S. Ellis Ave, #405
http://www-unix.mcs.anl.gov/~tiberius/
