[Swift-devel] wiring swift and falkon together
    Yong Zhao
    yongzh at cs.uchicago.edu
    Wed May 23 12:10:48 CDT 2007
Because the Falkon provider code is not in SVN, and that install is where
you can get the Falkon provider code. But you did update your Swift code
to the lastest source code in SVN at that time (as you needed some
new features) as I told you to. So in that sense you were testing at least
some relative new Swift code.
Yong.
On Wed, 23 May 2007, Veronika Nefedova wrote:
> I think Yong told me to use his swift install from terminable when I
> started using Falcon. I am not sure why -- I presumed there were some
> specifics in that install.
> Nika
> On May 23, 2007, at 11:36 AM, Ioan Raicu wrote:
> > Hmmm... from my understanding, the Falkon provider is independent
> > of the fact that Swift will actually use Falkon or not.  There is
> > no requirement that Falkon be used, even if you have the Falkon
> > provider installed!
> > With that said, our statement about people avoiding the latest
> > version of Swift due to the Falkon provider doesn't make any sense.
> > Maybe Yong has more input on this...
> > About how Falkon gets deplyed, it is simply uncompressed, you
> > modify 1 or 2 config files, and use the included scripts to start
> > everything!  All this is in the included readme.txt in the Falkon
> > archive, downloadable online on my web site.  Once again, if
> > someone is not intersted in using Falkon, then I see no reason why
> > they would be doing anything different than before just because
> > there is now a Falkon provider in Swift.
> > Ioan
> > Ben Clifford wrote:
> >> i hear rumour that its sufficiently unclear how to wire swift and
> >> falkon together that people are avoiding testing swift code (more
> >> recent than the 8th of march build that Yong made)
> >> that is lame - it means large chunks of our app testing are being
> >> done with code that is 2.5 months old.
> >> I don't know how Falkon gets deployed alongside swift at the
> >> moment, so I don't know what to do to make this easier - are they
> >> written down anywhere?
> > Ioan Raicu
> > Ph.D. Student
> > Distributed Systems Laboratory
> > Computer Science Department
> > University of Chicago
> > 1100 E. 58th Street, Ryerson Hall
> > Chicago, IL 60637
> > Email: iraicu at cs.uchicago.edu
> > Web:   http://www.cs.uchicago.edu/~iraicu
> >       http://dsl.cs.uchicago.edu/
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > http://mail.ci.uchicago.edu/mailman/listinfo/swift-devel
