[Swift-devel] mappers on files that are inputs and outputs
    Ben Clifford
    benc at hawaga.org.uk
    Thu May 17 05:08:19 CDT 2007
On Wed, 16 May 2007, Mihael Hategan wrote:
> You should probably also add the input=true mapping parameter?
If I *remove* the input=true mapping parameter that the translater puts
there, it works (which is consistent, I suppose, with this working when
used as an output).
This is in bug 60, http://bugzilla.mcs.anl.gov/swift/show_bug.cgi?id=60
and I'll poke round at it more later - I can work round by using the CSV
mapper for now.
