[Swift-devel] mappers on files that are inputs and outputs
Ben Clifford benc at hawaga.org.uk
Wed May 16 10:26:10 CDT 2007
Here's a code fragment:
  type volume {
      imagefile img;
      headerfile hdr;
  volume atlas <simple_mapper;prefix="atlas">;
  atlas = softmean(slices);
  string directions[] = [ "x", "y", "z"];
  foreach direction in directions {
      giffile outputgif
          <single_file_mapper;file=@strcat("atlas-",direction,".gif")>;
      string option = @strcat("-",direction);
      outputgif = slice_to_gif(atlas, option, ".5");
When this is run as part of a workflow, there are no atlas.* files and the
atlas = softmean(slices) line causes atlas.hdr and atlas.img files to be
created and placed in my working directory, and also used in the
subsequent slice_to_gif calls.
If I prune the program in a text editor so that the altas = ... line is
not called, and leave the atlas.hdr and atlas.img files in place in my
current directory (so that the files are now input files, rather than
intermediate files), I get this error:
  $ swift -debug -tc.file tc.data play.swift
  WARN   - Failed to configure log file name
  Swift v0.1-dev
  RunID: mx49u8a36d1m0
  Execution failed:
          java.lang.RuntimeException: Data set initialization failed for
  true. Missing required field: img mapped to atlas
I think its probably a desirable feature that the same mapping that maps
ok for intermediate files to map for input files too.
