[Swift-devel] swift-on-ec2
    Kate Keahey
    keahey at mcs.anl.gov
    Wed May 16 09:37:52 CDT 2007
Thanks Ben, this helps a lot! So it seems to me like we are talking
about combining dynamic provisioning with lightweight job management
which should be pluggable into swift.
Ben Clifford wrote:
> On Tue, 15 May 2007, Kate Keahey wrote:
>> As Ian says, Borja and I were planning to meet with Ioan on Thursday to
>> discuss interaction between Falkon and the workspace service (not
>> necessarily/exclusively in the EC2 context). I don't completely
>> understand the relationship between swift and falkon -- are there
>> specific applications or scenarios that you are trying to target in this
>> exercise?
> By virtue of the fact that they come from pretty much the same group of
> people, they're somewhat fuzzily related - but pretty much swift is
> generating (over the duration of its execution, rather than in one batch)
> a bunch of jobs that need executing (as well, as various things like file
> transfers). As it generates them, it sends them off to be executed. The
> official ways that are 'supported' by Swift are by executing them on the
> local machine and by sending them off through GRAM; however, people can
> plug in whatever they want to do submissions.
> I know less about Falkon because it isn't Swift, but the Falkon side of
> things is pretty much about running a bunch of jobs - it plugs into the
> abovementioned place in Swift so that Swift gives Falkon jobs to run, and
> Falkon runs them (with a goal of Falkon being, presumably, to run it much
> more efficiently than if they were submitted straight through GRAM - it
> seems to do pretty well).
> There's two things going on with swift - one is about making it
> straightforward to use at the low end of things, so that people can start
> using it easily - for the most part, that isn't interesting in itself; the
> other is about getting it to perform well at the high end of things, which
> is where the fun research is. Using Falkon and using EC2 are both on that
> side of things.
Kate Keahey,
Mathematics & CS Division, Argonne National Laboratory
Computation Institute, University of Chicago
