[Swift-devel] swift-on-ec2
    Tim Freeman
    tfreeman at mcs.anl.gov
    Tue May 15 15:45:00 CDT 2007
On Tue, 15 May 2007 16:20:03 +0000 (GMT)
Ben Clifford <benc at hawaga.org.uk> wrote:
> Ian asked about this elsewhere, but its perhaps interesting for
> swift-devel people to look at the questions too.
> On Tue, 15 May 2007, Ian Foster wrote:
> > Dear All:
> > I asked Kate if she and Tim could look into creating VM images that
> > would allow us to run Swift applications on Amazon EC2. I think Kate is
> > meeting with Ioan about this on Thursday (?).
> > One issue that I thought would be good to discuss is what we'd want in
> > that VM image. Perhaps this is obvious to the rest of you, but it isn't
> > to me. A few thoughts:
> > * I'm assuming that we want to run "workers" on EC2 nodes, and have the
> > "task dispatch" logic run on some external frontend system outside EC2.
> > * I would think that we want to use Falkon to do the task dispatch. If so,
> > we need a Falkon executor on each VM, configured to check in with the Falkon
> > dispatcher. (Alternatively, we could use, say, SGE: in that case, we would
> > want an SGE agent.)
> > *  We need a way of getting data to and from the worker nodes. Do we want to
> > run a file system across the EC2 nodes and the external frontend node? That
> > seems rather inefficient. Other options?
> > * Should we preload the application code on each EC2 node?
> Here's a couple of approaches:
>  1) swift regards all the EC2 nodes that we are paying for as a single
>     site.
> Something like falkon handles all the task dispatch and worker node
> management. I don't know what that looks like at the moment in Falkon, but
> the interface for Swift to send jobs into Falkon sounds pretty
> straightforward and shouldn't need changing.
So if I understand, here there would be no gateway+LRM but each EC2 node +
Falkon would need a port open to receive tasks?  Or does each node pull down
instructions OK from behind a firewall?
Is there a latency problem with running each node as an indepdent task
receiver with the dispatcher off-site from EC2?  I would think it would be
better to put the queues to fill with tasks on EC2 so it can more quickly get
the task going when a node is done with a previous task (I may be missing some
nuances here with respect to Falkon, don't know much about this yet!).
If a gateway node is desired, this option sounds a lot like the GRAM+LRM
situation we use on VMs with the workspace service and will soon use on EC2 via
the workspace EC2 gateway we're implementing.  Start up one gateway node and
then add compute nodes which dynamically join the pool, they are pointed to the
GRAM node.
> All the nodes in a site are required by our site model to have a shared
> filesystem - we've talked about removing it, but I think that is still the
> case and if so, isn't going to change soon.
Setting up a shared filesystem in this environment is akin to setting up the
compute nodes to join an LRM pool.  The VMs can communicate over the private
network at EC2, you can instruct EC2 to let all the nodes be open to each other
(while simultaneously keeping a separate policy of blocking ports from being
open from the internet and other people's EC2 nodes).  The non-file-serving
nodes would simply need to know the private address of the filesystem server
(unless you are using a fancier network file system than NFS-style ones).
For background: every VM on EC2 currently gets a public address -- NAT'd to a
private address which is actually what the VM's one NIC is configured with.
There is a facility to open/forward specific network ports on the public
address to each VM either via a group policy or on a VM by VM basis.
> Amazon also has a storage cloud, alongside its compute cloud. I know very
> little about that and have never thought about how it would fit into the
> above (if at all). Maybe someone else knows more.
A VM template on EC2 is called an AMI which stands for Amazon Machine Image.
This is just a packaging thing but what it mostly means is that the VM is
stored on S3 and also registered into the EC2 system.
When starting an instance of an AMI, the file is copied from S3 to the
hypervisor node (what we call propagation in the workspace service).  After it
is used, this file is deleted (an option in the workspace service but there is
also an option to save it back with any changes).
So the VMs are stored in S3 but anything that happens on them after being
started is lost unless you manually do something about it.
As for free scratch space, you get a good amount per node, 140G.  But the node
could go down at any moment just like a physical resource.
To harness S3 for safely persisting any data (or if you need more space) you
would need to actually run S3 clients on the VMs when they are run on EC2.  You
could alternatively mirror data between nodes assuming that all would not go
down at once.
The good thing is that you do not pay transfer costs between S3 and EC2 if you
chose to use S3 for big storage, you would only pay the "housing fees" so to
speak.
Tim
