[Swift-devel] MolDyn at Purdue
Ben Clifford benc at hawaga.org.uk
Thu May 10 01:47:55 CDT 2007
As you suggested, the GRAM4 RSL extension to use is
<project>whatever</project> according to
http://teragrid.org/userinfo/jobs/
Probably needs to go under extensions, (in xpath, extensions/project)
On Wed, 9 May 2007, Ioan Raicu wrote:
> Hmmm... I don't know.  If you know what modifications we need to make to the
> GRAM4 RSL to include the specific project, we can simply modify the RSL by
> changing the create function to add the extra info into the RSL... its a minor
> change, but we'd have to recompile the DRP stuff again.  If we can't add it to
> the RSL, then I don't know any other place to put this.  Anyone have any
> ideas?  I am using the GRAM4 Java API directly in the DRP code.
> Ioan
> PS: Here is a sample RSL...
> iraicu at tg-viz-login1:~/java/Falkon_v0.8/worker> cat
> RSL.0.0.ia32-compute.1.120.14898358.xml
> <job>
>    <executable>/home/iraicu/java/Falkon_v0.8/worker/run.worker.sh</executable>
>    <directory>/home/iraicu/java/Falkon_v0.8/worker</directory>
>    <argument>6900000</argument>
>    <argument>1500000</argument>
>    <maxWallTime>120</maxWallTime>
>    <extensions>
>         <resourceAllocationGroup>
>            <hostType>ia32-compute</hostType>
>            <hostCount>1</hostCount>
>            <cpuCount>1</cpuCount>
>            <processCount>1</processCount>
>         </resourceAllocationGroup>
>     </extensions>
> </job>
> My guess is that we could add something like
> <project> ... </project>
> but I am not sure...
> If no one knows how to do this off the top of their heads, I'll look it up!
> Veronika Nefedova wrote:
> > Hi, Ioan:
> > How do I add my project info into Falcon? (I can't submit anything to PBS
> > queue unless I specify the project)
> > Nika
> > On May 9, 2007, at 12:16 PM, Ben Clifford wrote:
> > > Do this:
> > > edit your site catalog to add an entry <profile namespace="globus"
> > > key="project">TG-STA040020N</profile> for the purdue site, add an entry
> > > key="project">TG-WHATEVERYOURGRANTNUMBERIS</profile>
