[Swift-devel] Fwd: Re: chained genU workflow
Ben Clifford
benc at hawaga.org.uk
Wed May 2 03:52:47 CDT 2007
On Tue, 1 May 2007, Mihael Hategan wrote:
These should probably go into the bugzilla as they look like app
requirements that need tracking.
> - MPI jobs with the PBS provider. They need to be able to run with more
> than one version of MPI.
> - Easier configuration of tc.data/sites.xml. Basically they need the
> ability to use a global sites.xml while changing only things like the
> project profile entry.
It maybe makes sense in general that a commandline specified value
overrides a tc.data-specified value which overrides a sites.xml-specified
value.
Though in this 'project' situation, that might look wrong in the
multi-site case (though, given that they're using PBS on single site, that
isn't so much a problem at the moment)
> - The cleanup didn't work as it was. It would submit a job on the
> default execution provider (whatever that was) which needed a project
> profile entry, but the swift library didn't provide one. This was solved
> by hacking the vdl lib and adding /bin/rm in tc.data.
mmm hacks.
anything useful from a production codebase perspective?
> - They would like the cleanup to be done without pbs in the future
> (possibly fork or directly with the fileop provider). There's some
> thinking that needs to go here.
VDS1's sites descriptions allowed different job submission mechanisms to
be specified for different purposes - the 'vanilla' universe and the
'transfer' universe with the intention that the vanilla universe is for
running the meat of the workflow and would point at a batch system of some
kind, whilst the transfer universe is intended for lighter weight jobs and
would point at GRAM2's jobmanager-fork.
That's perhaps a starting point.
